Old 09-20-2010, 03:24 PM   #1
1_bar_of_boost
1_bar_of_boost's Avatar
Thumbs down Pilot Bearing nightmare
I have tried using the hydraulic pressure method to pop it out as well as use a steel hook to get behind it with -1% luck here...
B21 motor
Any other tips on getting this damn thing out...maybe I should just replace the block
Smokey told me to rebuild my engine
1_bar_of_boost is offline   Reply With Quote
Old 09-20-2010, 03:47 PM   #2
smith_t240
Abnormally Aspirated
smith_t240's Avatar
See if you can borrow a pilot bearing puller. I've used them before with great success. They are basically a 2 jaw puller that you screw on tight with a slide weight you slid/slam on the shaft of the puller.
Smith T.
83 244Ti white project car
07 S60R 6spd black the better DD
Originally Posted by Ktown_Brick View Post
I stubbed my toe while getting a beer this afternoon. I feel both your guy's pain. What a crappy day, ohh well, tomorrow can't get much worse for me
smith_t240 is offline   Reply With Quote
Old 09-20-2010, 04:13 PM   #3
jerryc
jerryc's Avatar
Many here are into bicycles; some bikeshops that were around in the 70's-80's had a puller to change 'sealed' bearings in some hubs and bb's, which were actually cartridge bearings that did in fact have a seal. This puller would work perfectly for this.
Originally Posted by Ursan View Post
What's the female equivalent to a dick pic? twat shot?
Originally Posted by XxJenoxX View Post
There isn't one because dudes aren't grossed out by unsolicited vaginas.
jerryc is offline   Reply With Quote
Old 09-20-2010, 04:58 PM   #4
Lord_Athlon
Just damn
You put grease in it and tried pressing it out? If there any air bubbles it wont work.
Go get a puller of some sort at Checker or Autozone.
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
Old 09-20-2010, 05:22 PM   #5
varg
kludgemeister
varg's Avatar
To get the pilot bearing out of my crank I made some pulp out of wet shredded paper and packed it in the hole. Then I used an appropriately sized socket attached to an extension bar and tapped it in with a hammer, withdrawing it to add more pulp as I went. Eventually it popped out.
'85 244DL B21FT swap (gone ), ->Project thread
'91 E30 318is, M20 swapped, turbocharged. project in progress.
Kawasaki ZRX1200R
varg is offline   Reply With Quote
Old 09-20-2010, 05:24 PM   #6
vvpete
Did you remove the steel snap ring first?
vvpete is offline   Reply With Quote
Old 09-20-2010, 05:28 PM   #7
towerymt
the real Towery
towerymt's Avatar
Assuming the snap ring is out, get a slide-hammer style puller.
Old 09-20-2010, 05:47 PM   #8
varg
kludgemeister
varg's Avatar
There wasn't one
Old 09-20-2010, 05:52 PM   #9
vvpete
There should be. And it wouldn't be the first time someone tried this w/o taking it out.
Looking at that pic, it sure looks like there is one still there.
Old 09-20-2010, 05:56 PM   #10
1_bar_of_boost
yes, snap ring out, unless there is a second one im struggling to see?
Old 09-20-2010, 06:05 PM   #11
vvpete
I had a troublesome pilot bearing on a B20 once, after I punched in the center of the bearing with a big hammer & chisel, I used a Dremel tool to grind out the remaining outer bearing race.
Old 09-20-2010, 06:32 PM   #12
Lord_Athlon
Just damn
Cut it out. Or replace block. I have a good b21ft you can have for free.
He blocked me. Someone quote it.
Old 09-20-2010, 06:33 PM   #13
Lord_Athlon
Just damn
Old 09-20-2010, 06:37 PM   #14
stylngle2003
stylngle2003's Avatar
i second the pilot bearing puller idea.
-Billy
Volvoless for the first time since 1990...
2002 Toyota Avalon XLS (comfy gradma car)
1996 Chevrolet Tahoe LS 2WD (hauls ass)
1990 Mazda Miata (track toy)
stylngle2003 is offline   Reply With Quote
Old 09-20-2010, 06:44 PM   #15
smokeyfan1000
Guest
Mine on the 91 240 was snug, but came out with not much hassle. Clean all the dirt & clutch dust out from in front of it. That'll help some maybe. Also,See if A/Z has a puller for it.
Old 09-20-2010, 06:44 PM   #16
towerymt
the real Towery
towerymt's Avatar
I've seen the snap ring, but my car never had one. The clutch had been replaced before I bought it, so it probably got left out. I never had an issue in the 100k+ miles I've put on the car.
Old 09-20-2010, 06:47 PM   #17
SwedishBrick242...
Trying to get somewhere
SwedishBrick242...'s Avatar
This thing?
http://www.harborfreight.com/3-jaw-p...ller-4876.html
I gotta deal with mine this weekend, so I'm glad this came up now...
-Logan
'06 Pontiac GTO (400hp Daily Driver)
'00 BMW 323Ci (Soon for sale)
'84 242 DL (Status: Coming together...)
SwedishBrick242... is offline   Reply With Quote
Old 09-20-2010, 06:58 PM   #18
fige
KING OF TBOT
fige's Avatar
The thing is, the pilot bearing is so small, the puller doesn't fit through the hole. at least the ones from checker or auto zone.
Anyone know if the harbor freight one actually works?
Originally Posted by diponyou View Post
yeah gotta wait for jbweld to dry before I do anything today
fige is offline   Reply With Quote
Old 09-20-2010, 07:02 PM   #19
SwedishBrick242...
Unless someone else answers, since it says the inside diameter it fits, I can measure the one I have when I get home from work.
Old 09-20-2010, 07:08 PM   #20
Lord_Athlon
Just damn
They make pullers for the purpose. They also make dremels and hacksaws.
Old 09-20-2010, 08:35 PM   #21
1_bar_of_boost
done. Made a tool
Old 09-20-2010, 08:54 PM   #22
Lord_Athlon
Just damn
Cool
Old 09-20-2010, 08:57 PM   #23
745 TurboGreasel
745 TurboGreasel's Avatar
Originally Posted by 1_bar_of_boost View Post
done. Made a tool
Make a pic for the next guy, or it didn't happen
. . No remorse . . . . No regret . . .War without end
Feedback
745 TurboGreasel is offline   Reply With Quote
Old 09-20-2010, 09:00 PM   #24
1_bar_of_boost
Will do tomorrow, had to hurry back home to watch my son, girlfriend had class tonight.
Went to harbor freight and once again tool did not fit, all the tools you can rent/buy are too large btw.
Old 09-20-2010, 09:24 PM   #25
BrickBaller
BrickBaller's Avatar
My method: home made slide hammer.
Find a bolt with a hex head just small enough to fit inside. Put two nuts on it with washers in between.
Take a section of coat hanger wire, double it up, and smash it securely between the washers and tighten it down.
Take something heavy with a hole in it, like a diving weight or even a bench vice. The heavier the better.
Twist some washers on the other end of the coat hanger wires so the heavy object can't slide off.
Hammer against the washers with the hex head bolt pulling out on the bearing. Work your way around the perimeter.
Also, PB blaster.
'91 745 with 15g and MBC
that's called a crutch. like a roll cage for a joint.
Originally Posted by casioqv View Post
Tbricks... where half the members need to spends months essentially sourcing and building entire cars from miscellaneous used parts before they can drive a few hours and drink some beer with their friends.
BrickBaller is offline   Reply With Quote
