Old 06-21-2018, 04:22 PM   #1
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Default 242 Fabricated door cards
I threw these pictures up on IG, but I figured there were individuals who would be interested in seeing this that aren't on there. So....
I decided to design a file to rout out some 242 front door cards from aluminum earlier in the week. Volvo did us 240 guys a tremendous solid by making the doors essentially flat, with only a few minor bumps.
This is a pic of the original file I drew from a tracing of a spare door card I have
Here is the card after routing
And installed
Plan is to add material at the top, that will get break formed into a "radius" and have a flat to attach the inside window scraper. This card can re-use all of the OEM door parts, and I will run a strip of felt tape on the high parts of the door so there should be minimal rattles.
1980 242 Turbo
2004 V70R
Old 06-21-2018, 04:41 PM   #2
The Full Banana
not yet good enough
The Full Banana's Avatar
I'm curious to see the end result after you finish it off. My wrinkly door cards have been bothering me for years.
-Tom 1980 242 T5
Old 06-21-2018, 05:02 PM   #3
Jack
junkman
Jack's Avatar
What are you doing for the upper panel curve
Old 06-21-2018, 05:12 PM   #4
SlowRide
Cold War Crumple Zones
SlowRide's Avatar
Ahem...
http://m.mkmotorsport.se/products/vo...dor-brandvagg/
Do it like that.
- Justin
1980 242 DL
240 Junk for Sale
Feedback
SlowRide is offline   Reply With Quote
Old 06-21-2018, 05:43 PM   #5
Old 06-22-2018, 03:45 PM   #6
Uncleknucklez
bruspeed
Update:
I broke the top with multiple flat bends, seems like it will work fine.
This area needs file work
This area seems "OK"
Because racecar I slapped some stripes on the prototype.
I will continue to adjust the file another time, and hopefully have a finished product by the middle of next week.
Old 06-22-2018, 03:59 PM   #7
Jack
junkman
Jack's Avatar
Adidas?
Old 06-22-2018, 04:02 PM   #8
Uncleknucklez
bruspeed
Adidas?
Meh, why not. It's just sign grade vinyl, So it can be peeled off. I also have a large format digital printer in my shop, and could pretty much print anything and apply it. This was something that took 5 minutes to cut and apply.
Old 06-22-2018, 04:03 PM   #9
Jack
junkman
Jack's Avatar
Russian ?
Old 06-22-2018, 04:06 PM   #10
SlowRide
SlowRide's Avatar
Russian ?
That squat tho...
Old 06-22-2018, 04:10 PM   #11
Jack
junkman
Jack's Avatar
Originally Posted by SlowRide View Post
That squat tho...
Slav squat YouTube dude is hilarious
Old 06-22-2018, 04:38 PM   #12
Russian ?
Romanian taxi car driver.
Old 06-22-2018, 06:27 PM   #13
GTJordan
Been here for too long
GTJordan's Avatar
Are you going to produce a couple of these?
Old 06-26-2018, 10:00 AM   #14
Uncleknucklez
bruspeed
I plan to make my final set today, and if everything goes well, I can produce reproductions no problem, I realize this isn't the classified section, but for reference I am thinking $160 shipped for the set will put them within reach of the TB crowd, and still make sense for me to produce them.
That being said aluminum prices right now are rough
Old 06-26-2018, 10:56 AM   #15
Stiggy Pop
Stiggy Pop's Avatar
I'd put some squares of butyl based sound deadening material (rec. RAAMmat). Might also be a good idea to use some strategically placed butyl rope strings squeezed down around your mounting perimeter. I can see that big piece of aluminum being a rattle and drum factory otherwise.
'79 242
943 pickup
Old 06-26-2018, 11:25 AM   #16
Uncleknucklez
bruspeed
My doors are covered in Noico sound deadening material.
I lined the high spots of the door frame with felt tape, and ordered some edge trim to combat that. However I am finding that these are quieter than the squeaking sounds the factory blown out door cards make as they rub the sill guard.
The real rattling right now is at the window where the scraper should be that I haven't installed yet.
Old 06-26-2018, 03:46 PM   #17
Stiggy Pop
Stiggy Pop's Avatar
my eye is twitching... it's the WORST. Problem on my car as well.
Old 06-29-2018, 12:10 PM   #18
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Honestly I like the pink!
Old 06-30-2018, 12:32 AM   #19
Forg
Forg's Avatar
Simple statistics would predict that ...
When I'm cruisin' in overdrive ...
Don't have to listen to no run-of-the-mill talk jive.
Shatner: The Colonel is breakdancing ... gimme a break!!
Rollins: Credit terms raised!
Shatner: I can't get behind any of that!
Shatner: I can't get behind so-called singers that can't carry a tune, get paid for talking, how easy is that? Well, maybe I could get behind that ...
Rollins: Well, I can't!!
Forg is offline   Reply With Quote
