Old 07-18-2018, 02:05 PM   #1
iHateVolvoPeople
Default Need submersible fuel line
Folks I need some 5/16"ID 'submersible' fuel line. I put submersible in single quotes because it only needs to last maybe a year or 2. This is an ultra low budget thing that is stopping the vehicle from being scrapped. I need about a 3 or 4 foot section of it.
Any leads as to what I could use? Owners are not paying some $16 a foot otherwise it's just going to the JY. I'm pretty sure heater hose will NOT work. TIA
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
Old 07-18-2018, 03:27 PM   #2
planetman
planetman's Avatar
We used to use high pressure fuel injection hose as submersible hose and although we haven't had any failures of any of the previously installed hoses, we recently started using only the Volvo submersible hose as a precaution.
So I can't see why you couldn't use the same FI hose especially if you are going to change it in a couple of years.
High pressure fuel injection hose is only about $2.00 or $3.00 per foot.
Eric
Torrance, CA 90502
Old 07-18-2018, 04:03 PM   #3
iHateVolvoPeople
Beautiful. Thank you very much.
Old 07-18-2018, 06:13 PM   #4
tryingbe
Boosting along.
tryingbe's Avatar
Bad advise. 30R9 hose are not made to be submersible. Use 30R10 hose or other specs that are made to be submersible only. Last I know, Volvo dealership sells it by one meter.
85 GLH 367whp
00 Insight mpg > yours.
Old 07-18-2018, 06:35 PM   #5
Wren
Porkchop Sandwiches
Wren's Avatar
You could probably take an old bicycle inner tube and with some hose clamps use that as a 'temporary' fix. It holds at least 40 psi on your paper route, so it would probably work for a low-pressure "application" like yours.
Old 07-18-2018, 06:40 PM   #6
iHateVolvoPeople
How old was this?
Old 07-18-2018, 07:36 PM   #7
mck1117
False. The tire holds in 40 psi, and the inner tube just seals inside the tire. Ever tried to inflate an inner tube while not in a tire? They get huge, and then pop.
mck1117 is offline   Reply With Quote
Old 07-18-2018, 08:24 PM   #8
iHateVolvoPeople
He was just being a smartass.
Old 07-19-2018, 01:35 PM   #9
mck1117
Gets me every time.
Old 07-19-2018, 02:05 PM   #10
Chuck W
Chuck W's Avatar
Get a foot of the proper submersible hose for connections and use some of the black plastic fuel line for the rest.
'80 264GLE - (B21FT-MS'ed/M46)
'97 854 T5 (Eventually to be 5spd)
'77 242DL (B21F/M45) - SOLD '75 245DL SOLD '85 244GLT DEAD
My feedback thread
Old 07-19-2018, 07:04 PM   #11
freevolvos
freevolvos's Avatar
if 16 dollars will put this car in the grave i shudder at the thought of sharing the road with it.... that being said any f.i. house will work for a few months
freevolvos is online now   Reply With Quote
Old 07-19-2018, 09:02 PM   #12
lummert
lummert's Avatar
NAPA at $8 per foot last I checked.
Old 07-19-2018, 09:25 PM   #13
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
$14.99... Shipped. Otherwise crush.
Common man, 7/9s are better than that! Splurge for the $16.
#79WDP
Old 07-19-2018, 10:09 PM   #14
iHateVolvoPeople
Actually to be honest it’s a Chrysler Pacifica 07 with the 4.0. They had an engines for life hung going on and my in laws son launched the motor. It had a BRAND NEW 4.0 installed then the stupid Chrysler shifter thing broke, and it sat for 5 years. Needless to say the gas tank innards were crap.
Old 07-19-2018, 10:18 PM   #15
white855T
Find a hose in the junkyard?
Buyer/Seller Feedback
Old 07-19-2018, 10:30 PM   #16
iHateVolvoPeople
Stock stuff is one time use. Pretty sure I’m orfer to buy it new they want you to buy the entire drop in assembly as well. Near $400 in parts for a $500 car. Lol
Old 07-19-2018, 10:34 PM   #17
If you're insistent on dividing by zero 7-9 style just crush it now, otherwise take a look at the total cost and use value equation, and ask them if it pencils out for them.
Old 07-19-2018, 10:53 PM   #18
iHateVolvoPeople
I really just need something local. Have never been able to find SAE30R10 hose in anything longer than 18”. Plan is to call some speed shops tomorrow morning and if no one has any I’ll just have to settle for the R9
Old 07-20-2018, 08:51 AM   #19
tryingbe
Boosting along.
tryingbe's Avatar
Crush it.
Old 07-20-2018, 10:28 AM   #20
iHateVolvoPeople
Yeah that’s the pesseneger side of the tank. That’s not even a pump as far as I know. That side is fine just need the line. I ordered the driver side which is the pump and filter.
