Old 07-15-2018, 03:13 PM   #1
nolift911
Default Shaving Brake Calipers
Looking for a few mm's out of the shave, possible? Done before is there enough material? Trying to avoid having to run spacers and only need 1-2. Other options? Have some BBS RS that I am building and the pad height is just a C hair shy to clear - rears are fine.
Thanks -
nolift911 is offline   Reply With Quote
Old 07-16-2018, 09:17 AM   #2
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
I am not proud, but I have ground material off the front calipers on my car due to the curvature of the face of my wheels. There is a good amount of material on the calipers, and I didn't really find a source for a .250" aluminum spacer which would have cured what ailed. I say get after it with a grinder and soft pad and sneak up on it.
1980 242 Turbo
2004 V70R
Old 07-16-2018, 09:38 AM   #3
really depends on the brake caliper and where you shave the material. Devil is in the details.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 07-16-2018, 09:44 AM   #4
Uncleknucklez
bruspeed
Ha! Gotcha, I was hoping this thread would catch you, do you make a thin 5x108 spacer??
Old 07-16-2018, 10:39 AM   #5
We make long studs, thinnest hub centric spacer we make that fits the front of a 240 is a 15mm.
If you want thinner, just use the long studs with what ever flat generic spacer of your choice.
Old 07-16-2018, 10:59 AM   #6
I've posted those a billion times please do your research.
Old 07-18-2018, 08:41 PM   #7
neptune
Is 15 cars too many?
neptune's Avatar
I had to use the H&R 5mm spacers to clear the calipers when running BBS RA. Worked fine.
www.neptune242.com
1981 242 Turbo |1996 850R |1980 Coupé (Project)
neptune is offline   Reply With Quote
Old 07-19-2018, 11:43 AM   #8
nolift911
Did you use longer studs for 5mm? With the BBS RS wheels it seems right now I have "just enough" length on the studs...
Old 07-19-2018, 11:56 AM   #9
5mm should be fine with stock studs. Just verify the with a lug nut that you get enough engagement.
Old 07-19-2018, 08:12 PM   #10
neptune
neptune's Avatar
I used the stock studs. Had them on for at least a few years without any issues at all.
The bbs lugs I have were much deeper than stock lugs so there was a concerning amount of empty space in them, but I had plenty of threads actually engaged.
Old 07-22-2018, 07:02 PM   #11
J_pelchy
RedBrickRoad
J_pelchy's Avatar
I have long studs with a 5mm spacer up front with ocean mk18s. But i just hardly had enough stud to hold the wheel without spacer on stock studs so i definitley needed them to add a spacer. But i just used a cheap generic 5mm slip spacer and it works great.
Flint, Mi
*Volvo Enthusiasts of Michigan*
Instagram // 810_volvos
Feedback
J_pelchy is offline   Reply With Quote
