Old 07-17-2018, 11:46 PM   #1
ddininio
Default Volvo Amazon Flywheel removal
Hi All,
I'm having issues removing the transmission flywheel on my 122. B18 engine with M40 trans. I've removed the bolts. Do I need a flywheel puller to get the flywheel off?
Dave
Canadian 122s
ddininio is offline   Reply With Quote
Old 07-17-2018, 11:47 PM   #2
No it should fall off unless it's rusted on.
Old 07-17-2018, 11:56 PM   #3
planetman
planetman's Avatar
Re-install at least 1 flywheel bolt, but don't tighten the bolt, leave it a little loose.
Then using a prybar, gently move it off the back of the crankshaft, then remove the bolt and flywheel.
This way, the flywheel can't fall off until after the bolt is removed.
Eric
Torrance, CA 90502
Old 07-18-2018, 12:27 AM   #4
ddininio
Awesome. Thanks for the advice. I'm guessing it's a bit rusted on but I will give it try.
Old 07-18-2018, 01:00 PM   #5
AndrewNance
Amateur hour!
AndrewNance's Avatar
Hit it with your purse.
'71 142
'80 245
Feedback
