- Oct 21, 2004
- BFE Desert east of Cali
You'll need an adapter from I believe a 12mm or 14mm to a -8AN, but that's common at any decent shop that sells AN stuff.
As for results, didn't fix my stumble, but it's running perhaps a touch better than with the old one, and it sounds FAR smoother that the other one ever did, plus it's far quieter. Time will tell.
Looks like the advanceautoparts website still has the BIG40 discount going on. Select in-store pickup and you're paying $69.99
Think about it like this Toby...
Worst case, you're maxing your injectors.
70lb x 4 = 280lb/hr = 171lph
per http://convert-to.com/flow-units-converter.html
You're already past the limitations of the stock in-tank pump at 130lph, let alone the main which isn't more than 150lph at a lower pressure. Also swapping to a single in-tank pump you've got fewer components to fail, less electrical load, fewer connections, less weight, and less restriction in the system.
Wouldnt that calculation only be true if the injectors all fired simultaneously?
Given LH2.2 and 2.4 are batch fire, it still applies completely.
need to know for sure so i can delete my main, somebody anybody? pretty pleeeeeez
