Mylesofsmyles
A Member
- Jan 18, 2010
Well, it's a long story with this one, but I've nicknamed her "The Town Bicycle." Everyone seems to have gotten a ride.
It's an '85 245 GLT factory Turbo Intercooled car. Though it's hard to tell, this car's original color is #175 Redwood Metallic.
I got it from my best bud Dave (ButterflyBrakeChecker) who got it from Andy (AndysBeta) who had it for years and years and eventually swapped in the M46, before selling it to Dave.
So, now she's mine.
"THE LIST"
‘85 Volvo 245 Turbo
Exterior
Flathood Conversion
2-Screw Amber Turn Signals
Bosch Fog Lights (Side Mount)
‘84- GL Tailgate (No 3rd brake light)
‘80-85 Manual Adjustable Side Mirrors
Quad-Round Headlight Assemblies
Hella 5.75” H4/H1 Headlight Lenses
Clear Headlight Shields
Euro Flathood Grill
1-1/4” Tow Hitch
15” 740 Steel Wheels (15x6 et25)
Stainless Steel Hub Caps
Interior
‘75-‘80 Dash Board
R-Sport Gauge Cluster (vw volts & oil pressure)
3-Gauge Dash Pod (turbo boost, oil pressure, narrowband AFR)
MOMO Steering Wheel Hub
MOMO SAAB Steering Wheel
140 Chrome Door Latch Trim
Accessories& Revisions
EFI Fuel Delivery Hose
EFI Fuel Pump Tray (fuel filter relocated to pump tray)
K-Jet Turbo Airbox modified for EFI
Coil Relocated to Firewall w/ Custom Bracket
'91+ AC/HVAC Unit
'91+ AC Firewall Panel w/ EZK Computer Bracket
'91+ AC Dryer & Hard Lines
'91+ AC Condensor
Optimized Vehicle Wiring Harness:
Engine
Stock B21FT Long Block drilled for Knock Sensor
K-Jet Head injector plugs
EFI Intake Manifold w/ LH2.2 Throttle Body
"B" Cam
Bosch 850t "Orange-Top" High-Impedance Fuel Injectors
Electric Fan & Shroud
TLAO Silicone Coolant Hoses
Silicone Air Intake Couplers & Elbows
Stainless Steel Hose Clamps
'90+ Exhaust Manifold
TD04HL-13c Turbocharger
Custom oil feed & return line
Porsche 911 Manual Boost Controller
Modded 740 Downpipe
Mustang Muffler w/ Downturn Tip Before Axle
Drivetrain
1030 Carrier w/ 3.91 Ring & Pinion
Mustang 5.0 WC T5 Transmission, 3.35/.68
DeeWorks T5 Bellhousing Adapter
Mustang Fox Body Driveshaft
Yoshifab Driveshaft Adapter
Custom Transmission X-Member
JVAB Steel Flywheel
Sachs SAAB 9000 Aero Pressure Plate
ClutchNet 240mm Organic Clutch Disc
Suspension
242 GT Firewall Braces
Bilstein HD Struts & Shocks
IPD Wagon Overload Rear Spirngs
‘79 242 GT Front Springs
IPD 25/22mm Sway Bars
Poly Torque Rods
Brakes
ATE Atom Rotors
Yoshifab PTFE SS Front Brake Lines
Stainless Steel Rear Brake Lines
When I got it, it had a poor excuse for a murdered out formal grill and a white formal hood, with 81 DL black out reflectors on the quad squares.
I've fixed various electrical shorts in the Kjet harness, replaced front brake pads and rotors and changed the motor oil.
It's been a rock solid car, despite having wastegate actuator issues. I've got to free up the wastegate door or replace the turbocharger soon.
It's become the product of my necessity for a simple, dead reliable work vehicle, and whatever else I could find in the garage.
In TB fashion, she sports a black flathood, quad round headlights and no grill...yet.
I deleted the power mirrors for simple, black plastic manual mirrors. Cruise control has been deleted as well.
The dash had some cracks and fading, so I swapped in my flawless '80 dashboard.
Slowly, but surely, all the brightwork is being upgraded to stock '83 DL trim.
Stay tuned.
In the mean time, explore the world of parts I have for sale,
And my other project.
So, now she's mine.
"THE LIST"
‘85 Volvo 245 Turbo
Exterior
Flathood Conversion
Euro Flathood Grill
1-1/4” Tow Hitch
Interior
‘75-‘80 Dash Board
'91+ AC/HVAC Unit
'91+ AC Condensor
Main Harness
Repair Rotten Wires
Center Brake Light Delete
Power Mirror Delete
Cruise Control Delete
K-Jet Delete
Factory Speaker Wiring Delete
Shift Lock & A/T Ignition Inhibitor Delete
Fog Lights & E-Fan integrated with main harness
Custom stereo wiring integrated, heavy speaker cable & RCA
Reroute Coil Leads to Firewall Connector
Dash Dimmer & Rear Fog switches relocated to center
LH2.2 Engine Harness
LH2.2 541 ECU
EZK Ignition Integration
Ignition Control Module relocated to firewall bracket
Coil leads to firewall connector
Fused main power to starter
Oil Temp Lead Integrated
Re-route injector connectors
Integrate A/C Compressor Lead
Repair Rotten Wires
Power Mirror Delete
K-Jet Delete
LH2.2 541 ECU
Engine
"B" Cam
Modded 740 Downpipe
Drivetrain
JVAB Steel Flywheel
Suspension
Poly Torque Rods
Brakes
ATE Atom Rotors
Stay tuned.
