taylor84240harris
- Oct 29, 2013
Been having several issues with my 91 240 n/a auto that have slowly been getting worse. It has to crank for nearly 5 Seconds before it will start, Once it's warm it hunts for an idle and if it does settle on an idle its hi, around 1500- 1700 rpm. No codes currently and I've replaced throttle position sensor and idle air control valve, and crank pos sensor. I've also checked for vacuum leaks with none found. It does have an EGR and it seems to be working properly.
