- Jun 26, 2002
- Apache Junction, AZ
Ok so Lets just say I put on a set of Solid yet adjustable torque rods on my 945. What should the ideal pinion angle be for these cars again? Yes I know I need to raise my T5 output angle also but that is besides the point.
I thought I knew it but now I am having second thoughts as my last adjustment does not seem to of solved my problems.
And just to be sure I need to measure pinion angle plus driveshaft angle as it hits the pinion and then add those to get the final angle?
-2 degrees?
Thank You
Mike
-2 degrees?
Thank You
Mike
