Old 11-28-2018, 04:27 AM   #51
Volvo owner in France
Have you confirmed the wiring is good to the sensor before replacing it? I read most the thread. I forget tho.
Use a labscope to see the output signal.
The wiring is intact, and I did do a resistance test for the three wires coming off of the distributor before removing it from the car. Each seemed to be OK.
A 'labscope'; is that like the 'banc d'allumeur souriau' that was mentioned by Kay in a previous posting above? I'm living in southwestern France (which explains the French spelling for what I believe is a 'Distributor tester'). I've been searching the internet for antique/vintage car clubs in the Toulouse area, where I live, but have yet to turn up anyone capable of testing my 30-yr-old Bosch distributor.
Volvo owner in France is offline   Reply With Quote
Old 11-28-2018, 04:34 AM   #52
Originally Posted by dl242gt View Post
The trigger star wheel on the magnetic trigger type come off with two screw drivers after you remove a clip. This isn't installed that way? You can use two small screwdrivers to gently lever the trigger wheel up and off the distributor shaft? After removing a retainer clip. That pin is very important but you usually just make sure you don't loose it. It's not keeping the wheel on the shaft in my experience. It's for locating the trigger wheel in the correct orientation.
I have found and removed the clip from above the trigger star wheel. A site recommended by Kay ( https://www.nomaallim.com/distributor-rebuild.html ) talks about a second clip under the wheel. I have been unable to locate it, to, as explained in that linked article, 'push it down' before removing the wheel.
I've tried prying up with screwdrivers, but that hasn't worked for me.
Thanks for your interest in my problem and struggle.
Old 11-28-2018, 04:47 AM   #53
mocambique-amazone
pm sent
Old 11-28-2018, 10:59 AM   #54
This thread needs more Clean Flame Trap!
He developed a tester that was very neat for testing distributors at the junkyard. 9v battery, a LED, a beeper....
For testing Hall effect sensor.
This one is "impulse" sensor, I believe. I forget how it works i would have to look it up.
I know I could test it by measuring the output signal with an oscilloscope. It graphs the electrical waveform. A meter could also be used, but I like the visual.
Old 11-28-2018, 12:23 PM   #55
Thanks for your message, ZVOLV. That sounds like something that I could use.
Tom
Old 11-28-2018, 01:34 PM   #56
Here is my thread on how on how EZK works on LH 2.4
http://www.forums.turbobricks.com/sh...d.php?t=322395
Ok so I have re-read the thread. I have concluded you have a hall effect sensor.
Three wires. Power, ground, signal. Make sure you have power- you do. Make sure you have a good ground on the ground wire! Then finally, measure the signal out. I like to use a scope. Meters can also be used. At a bare minimum, make sure there is less than 2 ohms between the signal wire end-to-end.
I think you are on the right track. Its very possibly the sensor is bad based on your tests, but it's possible you didn't do it correctly.
Here is a hall effect sensor article I googled.
https://www.google.com/url?sa=t&sour...6z60ZjVQfxmkJv
Old 11-28-2018, 05:58 PM   #57
cleanflametrap
cleanflametrap's Avatar
Default Hall Sensor Replacement
Yes, a Hall sensor distributor. Terminology is variable, but I associate "impulse" sensor with the reluctor and coil of the breakerless ignition, or even that of EZ116K with its crank sensor. This is TZ-28 I believe, and uses the Hall sensor. I've been staying out of the thread because I thought Dave had given the correct advice as I understand it. How the distributor was determined to need a new Hall sensor, I didn't follow, but often that's not so important. Changing the part is an easier task usually, but in this case I'd want to be damned sure because I'd probably bend up the trigger wheel (vane) if I tried this. Apparently Dave, I mean dl242gt, has done it and that's what we need. The voice of experience.
-Art
Old 11-28-2018, 06:40 PM   #58
Can play the blues
Thanks for clarifying what I rwas referring to Art! I have only done this on the magnetic trigger for the older breakerless system we got on Kjet cars. But I knew the hall sensor setup in a Bosch distributor would be similar. You pry that trigger vane up and off and you have access to replace the hall sensor.
Old 11-29-2018, 01:24 AM   #59
84B23F
84B23F's Avatar
more Clean Flame Trap!...He developed a tester
Would this work?
Manual
Old 11-29-2018, 04:18 AM   #60
I think you are on the right track. It's very possibly the sensor is bad based on your tests, but it's possible you didn't do it correctly.
Thanks for having taken the time to re-read this sad-tale of a thread. I also appreciate the clear illustration posted by 'Clean Flame Trap' on removing the trigger wheel with a pair of 5mm round-shaft screwdrivers. I think that I'll try that before investing in the AutoWave waveform viewer that was also suggested (although I do believe that one can always use another tool, I've already exceeded my tool budget for 2018 :-).
Old 11-29-2018, 10:23 AM   #61
Originally Posted by 84B23F View Post
That's just a handheld scope. It eliminates the need for a laptop/desktop.
A meter can be used on the Hertz frequency setting to measure the output of a hall effect or crank sensor too. I just prefer the pretty image. On modern cars I just use the scan tool data. I'm invested $1,500 on personal scan tool equipment already for the stuff I do at the shop.
Clean flame trap: where is that picture of your homebrew hall effect sensor tester you made!? That may not be needed for the OP, but I'm curious.
OP. I would maybe go find a used dist and then test it with a meter set on Hertz AC setting. And do the same with your suspect one.
Old 11-29-2018, 06:01 PM   #62
84B23F
84B23F's Avatar
It's a quick and coarse means to evaluate DC voltage and wave pattern, including CAN BUS signals.
FWIW, here's their catalog They have an updated model with 2 channels. And they have an adapter to examine Secondary Ignition wires and COP ignition systems
Old 11-29-2018, 06:09 PM   #63
84B23F
84B23F's Avatar
Here
Old 11-30-2018, 03:35 AM   #64
Nice...
If you make one for the European market, I'll get my deposit ready to get on the waiting list.
Old 11-30-2018, 08:32 AM   #65
cleanflametrap
You have my pics better indexed than I do. Thanks.
Old 11-30-2018, 02:00 PM   #66
mocambique-amazone
Cleanflametrap, thank you. Very good and simple idea. I will copy this if you won't mind.
Cheers, Kay
Old 12-10-2018, 06:18 AM   #67
Update on Hall sensor replacement saga
Thanks to an illustration ("Replacing Hall pick-up") posted by Cleanflametrap, I was finally able to remove the trigger wheel from my distributor (the secret was having two, 5mm-diameter, round-shaft screwdrivers to pry with) and install my new sensor (see a photo of it in place).
Unfortunately, my prying buggered the lower of the two 14mm inner-diameter snap rings (see photo). I've had to order a replacement snap-ring from China or Singapore, or somewhere in Asia, and I'm hoping to have it for Christmas so that I can (excuse the pun) wrap up this repair job that began in early July.
The new sensor (YAY!!!!) came already installed on a new base, eliminating me to have to play blacksmith, drilling out the attaching rivets and then beating in new rivets. There's no apparent damage to the old sensor, but I did clean out a lot of gunk from the inside of distributor, and the screws that hold in place the sensor were rusted in place (success was mine, however, thanks to WD40). I attribute that gunk and rust to the burst upper radiator pipe that I suspect poured water into the distributor, but maybe it's just an accumulation of 31 years of sitting outside.
Whether or not this old, gray lady starts when everything is back in place will likely tell me if my hypothesis was correct. I'll keep the forum updated.
[IMG]Distributor w: new sensor by Tom Fiorina, on Flickr[/IMG]
[IMG]snap rings by Tom Fiorina, on Flickr[/IMG]
[IMG]old Hall sensor by Tom Fiorina, on Flickr[/IMG]
PS: I nearly had a heart attack when I thought that I had lost the tiny rod that holds the trigger wheel in place on the distributor shaft. I swept every inch of my office/newly designated workshop floor, twice... This effort included moving a piano, desk and a 95-pound labrador. However, I finally determined that the rod, which had squirted out of the small, plastic tweezers that I had confiscated from one of my son's bug-collecting kits like an errant, miniature missile, had lodged in the vice that was holding the distributor while I worked on it.
Old 12-10-2018, 09:47 AM   #68
freevolvos
freevolvos's Avatar
Thanks for keeping us up to date
freevolvos is online now   Reply With Quote
Old 12-10-2018, 10:15 PM   #69
84B23F
84B23F's Avatar
Originally Posted by Volvo owner in France View Post
....replacement snap-ring...
Rotor Clip vous offre une gamme complète d’anneaux d’arrêts (circlips, bagues de retenue), d’anneaux en spirale, de ressorts ondulés, colliers de serrage auto compensateurs conçus pour répondre aux besoins spécifiques croissants des secteurs de l’automobile, l’aérospatiale, l’électronique et du secteur industriel en général.
Old 12-10-2018, 10:56 PM   #70
Old sensor "looks good"....I don't see any rotted wiring.
I'm gonna guess no spark....good luck.
One can use a meter set to AC Hertz frequency and measure the sensor output signal.
Old 12-11-2018, 03:27 AM   #71
Thanks! This is a great website. I'll keep it in mind for the future.
Old 12-11-2018, 03:39 AM   #72
I'm not sure my digital multimeter can measure Hertz frequency. It appears that I can use it just to test for the following: DIRECT VOLTAGE, DIRECT CURRENT, ALTERNATING VOLTAGE, DIODEs & CONTINUITY, AND ELECTRICAL RESISTANCE. But thank you for the suggestion.
Old 01-11-2019, 06:42 AM   #73
Default New Year update
The French say that you have until the end of January to wish people a Happy New Year, so I'll abide by that custom to wish all of the followers of this thread a healthy, prosperous, breakdown-free 2019.
Some of you undoubtedly thought that I got my 240 running again and just neglected to post that bit of information. Unfortunately, that's not the case, even though I managed to install the new Hall sensor in my distributor just before the new year began. Sadly, it didn't make any difference, and the old grey lady is still a fixture of our back yard where she's sat since last July.
I hope to evict the spiders that have been busy spinning webs on her during the past six months and, as soon as the temperatures rise above freezing, begin again to try and diagnose the problem. I've purchased, as several of you suggested, a multimeter with a frequency mode, and I'll first verify that the new sensor is putting out the proper sensor output signal. I'll then go through the necessary fuel, spark, ignition tests.
With any luck she'll be running again before long. I promise to let you know when that happens.
Regards,
Tom
Old 01-11-2019, 09:31 PM   #74
Do you have power to the hall sensor?
Old 01-12-2019, 12:27 PM   #75
Can play the blues
Thank you for the well wishes. A Happy New Year to you as well. It sure seems like you are very close to figuring this out. Have a good weekend.
