Old 12-04-2018, 02:39 PM   #1
nickvolvo746
Question 760-Advice to noob?
1990 760 turbo wagon
Newb here,
Just picked up a minty old brick recently, and unfortunately it did not come with a manual. I am having trouble figuring out exactly what systems the thing runs on on (ezk, rex regina etc..). Can anybody help me figure out how to do this? Also, I have been told it has the sought after B230ft, but is there a good way to confirm this? Any help here would be greatly appreciated, thanks if you are reading this!
nickvolvo746 is offline   Reply With Quote
Old 12-04-2018, 02:55 PM   #2
iHateVolvoPeople
If it is a turbo 4 cylinder (which it is) it is a b230ft engine with 13mm rods and no squirters. Pretty stout engine.
And it runs on LH2.4 turbo ecu and EZK116 ignition.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
Old 12-04-2018, 03:09 PM   #3
nickvolvo746
Thanks very much for the response mate. If I may be so bold as to follow up, if I was told that it does have squirters, was I lied to or is there a chance it was upgraded? Can I test this somehow, are squirters easy to see? Not really a big deal either way but it sounds like squirters are nice to have.
Old 12-04-2018, 03:49 PM   #4
300+hp on the shelf club
If this is a US market model vehicle then it has the systems described above. there might be slightly different engines if it is not a US model.
Old 12-04-2018, 04:17 PM   #5
nickvolvo746
Awesome, thanks for that.
Old 12-04-2018, 05:07 PM   #6
iHateVolvoPeople
Oh I forgot to consider the fact that you may not be US based, but I believe most of the time the injection systems will be the exact same. Other countries I think got a B200ft? Not sure..
Squirters are generally 93+. I have never seen them in a pre 93 car but I am a small sample size (maybe 5 engines). Pulled the pan on a 92 yesterday...no squirters.
It is unlikely that you have them and the only real way of telling is by pulling the pan or using a borescore through the the drain plug hole. You probably won't notice a difference either way though.
Old 12-04-2018, 06:48 PM   #7
lummert
lummert's Avatar
You may be more likely to find specifications for a 1991 940 SE, or a 1991 960 Turbo. Depends on what continent you're on.
Old 12-04-2018, 09:24 PM   #8
nickvolvo746
Thanks a bunch for the info guys! Also Ill add to my profile that I am US based. Jersey boy, heh
Old 12-05-2018, 12:01 AM   #9
Hacksaw116
Welcome to the gang.
Hacksaw116
Hacksaw116 is offline   Reply With Quote
Old 12-05-2018, 04:19 PM   #10
Get in touch via PM if you need help with your car. We have a good group of people here in NJ.
Old 12-05-2018, 11:17 PM   #11
nickvolvo746
Thanks! Ill keep that in mind. Do you guys ever have meet ups or anything? I spend a lot of time on here just reading through random posts to try and glean whatever knowledge I can, I wish I had somewhere I could hang out and see stuff getting done first hand.
Old 12-07-2018, 09:17 PM   #12
Wren
Porkchop Sandwiches
Wren's Avatar
Here's a wiring diagram for your car. Be on the lookout for a spare fuel relay and headlight relay. Also, the heater fan controller is NLA.
https://web.archive.org/web/20160624...20Diagrams.pdf
Old 12-08-2018, 02:29 PM   #13
nickvolvo746
thanks man! I assume theyre hard to come by then...and also how did you know i was looking for the heater fan stuff????
