Old 12-01-2018, 07:58 PM   #26
smeha
Tranny Whisperer
smeha's Avatar
Never seen presumably well serviced working 240 engine drinking a Kool Aid especially in pics. Thanks!
1997 Jeep Cherokee Sport (XJ) (Engine: 4.0L - I6) (2WD)
My Feedback Thread
<--- Just a dumpster on fire
Old 12-01-2018, 08:08 PM   #27
swedefiend
swedefiend's Avatar
http://forums.tbforums.com/showthread.php?t=60348
Pic is gone from thread. Car is ~gone from life. I wish I could help you out here. Anyway.
Old 12-01-2018, 10:04 PM   #28
Install a new head and forget about your problems.
Old 12-01-2018, 11:14 PM   #29
iHateVolvoPeople
Originally Posted by swedefiend View Post
Imperceptible loss of compression. Smooth the edges with Emory cloth and run it.
Overrevving a high lift cam on factory springs is one sure fire way. BTDT.
So you’re telling me i shouldn’t bang limiter burnouts with my +t iPd turbo cam..???
Also, was this what we call 'dropping a valve'?
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
Old 12-02-2018, 02:36 AM   #30
EivlEvo
I snapped a bad pic of the aforementioned missing chunk on the block where the head bolt would go. If you look, you'll notice a missing chunk just above the purolator oil filter in the pic.
I'm not sure what that hole/channel is for... presumaby the water jacket? But I'm also not sure anything is "missing" or if it's a casting issue or... well I'm just not sure, but I also don't see what potential harm exists?
Old 12-02-2018, 02:38 AM   #31
esmth
dirty swede
esmth's Avatar
Mine had the same drilled notch when I did the HG. I assumed it was fine
Old 12-02-2018, 04:28 AM   #32
Acke
That's normal. My blocks have looked the same.
Old 12-02-2018, 11:49 AM   #33
swedefiend
swedefiend's Avatar
It's your car.
Yes, obviously.
