Old 11-13-2018, 12:39 PM   #1
iHateVolvoPeople
Default LH2.2 engine in LH2.4/3.1 car
Iím going to be swapping an ~88 lh2.2 b230f into a 92 240 with lh3.1. I know itís not ideal but itís the motor in hand. Had a few questions before I dive in as to not run into any major unexpected inconveniences.
1) I assume this is the same case as b21>2.4/3.1 motor where I must drill and tap the 2 holes for the CPS bracket. Is this something that can be relatively eyeballed? Plan was to trace the old block, mark the new block, and then tap/drill for m6.
2) 2.2 > 3.1 sensors like, tps, cts, etc etc is as simple as a direct swap from old to new. I think the only issue here will be the knock sensor. The new block should have a spot for it to mount to, and I will just have to grab a torque wrench for this portion so itís the correct sensitivity.
3) For flywheel/clutch stuff, just direct swap from 3.1 motor to 2.2 motor? Both engines were backed my manuals. Gotta be careful with flywheel alignment but Iíll just put both engines at TDC (or whichever position the 3.1 engine is locked up at ) and swap straight over.
I think thatís it but if you know of any other obvious things please let me know. Thank you
Feedback Thread
Current:
93' 244T M47
93' 245 M47
90' 744 AW70
94' M-Edition Miata 5 speed, 93k
95' Camry A140E, 246k
91' 745 Regina AW701, maybe future turbo project
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
Old 11-13-2018, 03:39 PM   #2
iHateVolvoPeople
Just took a look at the back of the 88 motor. It appears that Volvo has already drilled and tapped the earlier blocks for the CPS bracket.
Old 11-13-2018, 05:30 PM   #3
sbabbs
sbabbs's Avatar
Yeah my 84 b23ft was drilled and tapped for the crank sensor. Just swap all the sensors over and go basically, some are the same, but unless you know just swap and go.. Everything will bolt on over, it's the same motor.
Old 11-13-2018, 07:43 PM   #4
lummert
lummert's Avatar
Don't forget about the flywheel/flexplate.
Old 11-13-2018, 07:51 PM   #5
freevolvos
freevolvos's Avatar
Dammit lummert
Old 11-13-2018, 08:04 PM   #6
iHateVolvoPeople
Thanks everyone.
@Lummert: Donor motor has no flexplate or flywheel, going to just directly swap from the old one.
Old 11-13-2018, 08:06 PM   #7
freevolvos
freevolvos's Avatar
Make sure the #1 cyl is at tdc and the flywheel is lined up
Old 11-13-2018, 09:11 PM   #8
iHateVolvoPeople
Probably can't even get the locked up engine to TDC But I will make sure both engines are at the same position before I swap everything over.
Old 11-13-2018, 09:22 PM   #9
300+hp on the shelf club
Put the new engine at tdc and use the flywheel missing tooth in the starter hole method to get the timing right. Don't need a locked up motor for reference that way.
Old 11-14-2018, 10:29 AM   #10
A tough rowing ho
TDC occurs twice per cam revolution, make sure cam is at the timing mark and put the blank holes in the starter hole.
1980 Richelieu red JDM flares franken-242DL now with 8.8, 1989 silver 780 sienna rear spring nivomat delete.
Old 11-14-2018, 01:27 PM   #11
Old 11-14-2018, 02:09 PM   #12
Lord_Athlon
churd sucks
Are you implying that the rear of the crankshaft could possibly be out of time in comparison to the front of the crank? TDC is TDC.
Yet Asher here went with...
Lord_Athlon is online now   Reply With Quote
Old 11-14-2018, 02:15 PM   #13
A tough rowing ho
No but if you set it by the crankshaft and not the cam it could be 180įout. I see where you're going with this I guess I should have phrased it differently, number one piston can be at the top of the compression or exhaust stroke so you need to set it in relation to the cam gear and not the crank.
Old 11-14-2018, 02:50 PM   #14
sbabbs
sbabbs's Avatar
Pull oil filler cap on top of valve cover look down hole make sure first two lobes on cam are up and piston number one is up by pulling spark plug and then that is top dead center with both cam lobes up offset from straight up in a V configuration and piston number one at the top pull spark plug put chop stick down hole to feel piston at top of cylinder look at first two lobes on cam make sure they are both up that is top dead center. NOW put in flywheel with missing crank sensor holes at starter hole closer to lower starter bolt hole then top starter bolt hole.
Do not look at marks on any gears. LOOK at piston and cam lobes then verify cam and gear marks are in correct spot also.. Why gamble.
Old 11-14-2018, 03:20 PM   #15
Default Doing too many bongs today?
Remove cylinder head and make sure piston 1 and piston 4 are TDC. NOW you can install flywheel.
Old 11-14-2018, 05:11 PM   #16
iHateVolvoPeople
A breaker bar is able to move the 'seized' engine i believe, so I’ll just put both to TDC and swap. Thanks guys.
Old 11-28-2018, 07:30 PM   #17
iHateVolvoPeople
Breaker bar could NOT move seized engine. So anyway, here is the new engine with cylinder 1 at confirmed TDC. I need confirmation that this is the correct flywheel orientation.
Keep in mind the engine is sitting straight up and down rather than the normal 15 degree tilt.
Old 11-28-2018, 11:20 PM   #18
thismachine13
Blank spot at starter hole.
Old 11-28-2018, 11:56 PM   #19
iHateVolvoPeople
Yeah so it looks like I have it right. I was just concerned that it could be advanced or retarded a whole bolt hole and still be in the starter area. Time will tell. Buttoning up the rest tomorrow morning/evening and will try to start it.
Old 11-29-2018, 12:24 AM   #20
Yep. That's correct.
Maybe you should install the cylinder head just to be sure...
Old 11-29-2018, 01:57 PM   #21
iHateVolvoPeople
She started right up and is running well. Thanks guys.
Old 11-29-2018, 03:04 PM   #22
I was joking about the cylinder head part. Seems some people think there is a different crankshaft number 1 TDC when you involve a cylinder head.
Glad to hear it's running.
Old 11-29-2018, 03:30 PM   #23
iHateVolvoPeople
Yeah I was confused by that statement lol. Just put the engine at TDC (cyl 1) and work from there. But piston 4 is also at the top of it's stroke, but can't remember if both valves are closed on that one too. I would think it's either on an intake or exhaust stroke but idunno.
Old 11-29-2018, 08:44 PM   #24
A tough rowing ho
Firing order is 1342, that would indicate the intake valve would be open and exhaust valve would be closed on number 4. Y'all are a bunch of d-holes, I was just saying pr should make sure he was at tdc not at the end of the exhaust stroke on number 1. He's young and easily influenced.
Old 11-29-2018, 09:03 PM   #25
iHateVolvoPeople
Ah I gotcha. I always know TDC by verifying that the rotor is pointed near the number one spark plug lead, piston 1 is at the top of its stroke, and both valves on cylinder 1 are closed (lobes facing upwards-ish around 45 degrees). So cylinder 1 TDC was never an issue, just wanted to confirm i was installing the flywheel correctly because I did not want to pull the trans.
