Old 11-29-2018, 09:34 PM   #26
A tough rowing ho
Originally Posted by PromiseRing View Post
Ah I gotcha. I always know TDC by verifying that the rotor is pointed near the number one spark plug lead, piston 1 is at the top of its stroke, and both valves on cylinder 1 are closed (lobes facing upwards-ish around 45 degrees). So cylinder 1 TDC was never an issue, just wanted to confirm i was installing the flywheel correctly because I did not want to pull the trans.
Which you can also verify by having the cam on its timing mark, that's all I was saying- give peace a chance...
Me for President
First candidacy driven entirely by smart phone.
Campaign slogan
"Trump, I wouldn't piss on him if he were on fire!"
Old 11-29-2018, 10:05 PM   #27
iHateVolvoPeople
Lord_Athlons daddy
Yes but I like to verify in multiple ways for good measure:-) I am at peace, thank you!
Feedback Thread
Current:
93' 244T M47
93' 245 M47
90' 744 AW70
90' 745 AW70
94' M-Edition Miata 5 speed, 93k
95' Camry A140E, 246k
91' 745 Regina AW701, maybe future turbo project
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
iHateVolvoPeople is online now   Reply With Quote
Old 11-29-2018, 10:11 PM   #28
Firing order is 1342, that would indicate the intake valve would be open and exhaust valve would be closed on number 4. Y'all are a bunch of d-holes, I was just saying pr should make sure he was at tdc not at the end of the exhaust stroke on number 1. He's young and easily influenced.
Think harder.
Old 11-29-2018, 11:48 PM   #29
A tough rowing ho
Think harder.
You're the d-hole I was referring to, I reckon both valves are slightly open during overlap but it's the top of the intake stroke and the intake valve will be fully open shortly as well as the exhaust valve being completely closed. Go check your ocilloscope for some random waveforms.
Old 11-30-2018, 03:38 PM   #30
Old 12-04-2018, 02:00 PM   #31
iHateVolvoPeople
Lord_Athlons daddy
So got bored yesterday and wanted to look at the previous engine carnage. Dropped the oil pan and there was NO oil in it. The oil light was never connected on the owners car so he did not know it had no oil pressure. Needless to say, I wired it up to worked (I actually just plugged it back in)
Anyway, after dropping the pan and seeing no oil, I removed a main cap and rod cap. Both had scoring but really weren’t that bad. All rods remained in tact as well. So I’m not sure exactly where the failure occurred. Perhaps the pistons got hot and expanded until she seized?
Old 12-04-2018, 02:21 PM   #32
Maybe somebody had put the flywheel on during the wrong stroke for cylinder 1....
Old 12-04-2018, 02:29 PM   #33
iHateVolvoPeople
Lord_Athlons daddy
Idk man. Ran pretty well for 26 years or so.
