Old 11-26-2018, 08:37 PM   #1
89_740Turbo
89_740Turbo's Avatar
Default 740 idle issue - how to clean IAC?
How difficult is it to clean the IAC? My 740 has an idle issue which causes it to fluctuate, so I am going to: change the oxygen sensor, clean the throttle body w/ new gasket and looking to clean the IAC. What do I use to clean the IAC and how difficult is it?
1989 744Ti
1988 744Ti
1986 744GLE (RIP)
Old 11-26-2018, 09:29 PM   #2
Pro Sneaker Peddler
fill it with brake cleaner and let it soak a few minutes. Then shake the bejeezus out of it until it frees up. You will feel the valve knocking about. Once that happens you can drain it.
Old 11-27-2018, 10:14 AM   #3
89_740Turbo
Thanks!
Old 11-27-2018, 01:29 PM   #4
DET17
Reformed SAABaholic
Also, be certain your TPS connector has the pins landing on your throttle body. As the female pins are poorly retained in the plug, you can push it into position and it never makes. Without your "throttle closed" confirmation, the IAC will not function.
Permissives, always confirm the permissives.......
Old 11-27-2018, 02:39 PM   #5
Pro Sneaker Peddler
Easiest way to confirm is to check whether it jumps between 25* and 12* of ignition advance at as close to idle as you can get as you move switch position
Old 11-28-2018, 07:35 PM   #6
89_740Turbo
This all sounds risky as hell to me now...
Old 11-28-2018, 09:53 PM   #7
Pro Sneaker Peddler
Why
Old 11-28-2018, 10:02 PM   #8
smeha
Tranny Whisperer
smeha's Avatar
I've opened up mine to clean throughly, got new o-ring at local VatoZone and a but of RTV silicone to make sure it doesn't suck air.
Just got a be careful with internals.
1997 Jeep Cherokee Sport (XJ) (Engine: 4.0L - I6) (2WD)
My Feedback Thread
<--- Just a dumpster on fire
Old 11-28-2018, 10:29 PM   #9
2turbotoys
Salaminizer
2turbotoys's Avatar
I just douche the **** outta the IAC with brake cleaner, or MAF cleaner, whichever is closer and wipe it off where you can. Kinda like Harland says. Do that first, if it doesn't work then worry about TPS connections or misbehaving IAC (I just had that problem with an 88 240)
2006 V50 T5 AWD 16 PSI +
Old 11-28-2018, 11:25 PM   #10
89_740Turbo
Why
afraid of damaging TPS upon reinstallation
Old 11-28-2018, 11:54 PM   #11
smeha
Tranny Whisperer
smeha's Avatar
I have high idle when warm issue, definitely not IAC after all tests and all. Going for complete take apart throttle body and replacing TPS. Remind me if I forget to update how did it go.
Old 11-29-2018, 12:44 AM   #12
89_740Turbo
will do
also, very random question but what flange do I use with a 16t turbo?
Old 11-29-2018, 08:29 PM   #13
Pro Sneaker Peddler
There is no need to remove anything.
