Old 11-30-2018, 08:34 PM   #1
noz-e8tr
noz-e8tr's Avatar
Default Help needed
Hey guys. I fear I did something dumb and need help sorting it out. When I did my freeze plugs on the drivers side I unplugged all sensors and moved the harness out of the way. I normally label or take pictures so I can get everything back right. But I didnít do it this time for some reason. Iíll blame it on old age. Anyway, I have several connections that use the same connector. I was hoping they would just kind of ďfallĒ into place, but I still have like 3 identical connectors that ďcouldĒ go to any of the 3 sensors. Basically Iím looking at the knock sensors, the cold start injector and one other that hooks to a connector mounted on a thin metal tab What I really need is picture/video showing the sensors connection and where that connection goes to meet the wiring harnesses. Start with the knock sensors. Where does it connect to the harnes? A few pictures would probably help me figure it out. Video would be stellar.
Btw. 1990 740 Turbo. Help a dumb bro out.
Text pictures or video if possible to 361-815-5826. Or pm me. What ever works for you.
Berserker 242 Build Thread
This subculture is not conducive to meeting women let alone inspiring them to drive 30 year old, rectilinear, underpowered shit boxes.
Originally Posted by Walt Disney
"All our dreams can come true, if we have the courage to pursue them."
noz-e8tr is offline   Reply With Quote
Old 11-30-2018, 09:43 PM   #2
bobxyz
bobxyz's Avatar
There are some nice new harnesses, along with labelled pictures, available on Dave Barton's site -- 240turbo.com
Old 11-30-2018, 10:33 PM   #3
iHateVolvoPeople
Lord_Athlons daddy
If it’s anything like a 240, I may have some advice. Also, could peel back the rubber boot and check wire colors, then compare them with a wiring diagram.
On a 240, the knock sensor and temp sending plug come from the same loom. Only those 2 connections. Since they are different, it will be obvious that the one that isn’t the temp sensor, is the knock sensor. Then, on the other loom, I think it’s the IAC, TPS, and maybe a red wire for the starter? Anyway, based off the pics I took during my engine swap, one of the wires for the TPS is white/blue. So that one connects to TPS, and other would default to IAC. Also in my experience, cold start injector connector is always blue. Again, this is all from looking at and working on a 240 recently..
Let me check my 1990 744 NA.
Edit: my apologies. It’s a bit different from the 240 loom (duh). However, I can tell you that my CSI connector is blue, knock sensor connector is black, IAC connector is white/gray, and TPS connector is black.
Feedback Thread
Current:
93' 244T M47
93' 245 M47
90' 744 AW70
90' 745 AW70
94' M-Edition Miata 5 speed, 93k
95' Camry A140E, 246k
91' 745 Regina AW701, maybe future turbo project
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
iHateVolvoPeople is online now   Reply With Quote
Old 11-30-2018, 10:55 PM   #4
noz-e8tr
noz-e8tr's Avatar
This may help a lot. Iíll look closed at colors tomorrow.
Edit: my apologies. Itís a bit different from the 240 loom (duh). However, I can tell you that my CSI connector is blue, knock sensor connector is black, IAC connector is white/gray, and TPS connector is black.
Old 11-30-2018, 11:07 PM   #5
noz-e8tr
noz-e8tr's Avatar
Ok just went out in the rain and took a quick look. If the connector colors above are accurate on a 1990 turbo, I have the CSI and Knock sensors backwards. This is what I really needed to know.
Old 12-01-2018, 12:11 AM   #6
iHateVolvoPeople
Lord_Athlons daddy
Every CSI connector on a b230 lh2.4 Iíve ever seen is blue. So if thatís your only concern, Iíd swap them around. I would assume that the blue connector gets 12v on cold start cranking/idle. The knock sensor should not (assumed).
Old 12-01-2018, 10:31 AM   #7
noz-e8tr
noz-e8tr's Avatar
That’s what is was. Root cause of my car running crappy was my stupidity. CSI and knock sensors connection was switched.
Old 12-01-2018, 11:56 AM   #8
300+hp on the shelf club
Good find. Without the knock sensor detected the timing was always pulled making it run crappy.
Old 12-01-2018, 12:49 PM   #9
noz-e8tr
noz-e8tr's Avatar
Crappy does not even begin to describe how bad it ran. Guess that knock sensor is kind of important. Lol
Old 12-01-2018, 01:34 PM   #10
iHateVolvoPeople
Lord_Athlons daddy
I think thatís the case with every car on this forum.
