Old 12-05-2018, 07:57 PM   #1
smeha
Tranny Whisperer
smeha's Avatar
Question Volvo 245 Driver Kick Panel question
Hello,
Car in question 1988 245DL.
The driver seat has a plastic kick panel on the left side next to fuse box and hood popper.
How do you properly remove it? it seems something in the middle(all the way back?) holding it. I see some sort of plastic pin in the middle of a grill/vent(???) there, but afraid if I rip too strong, then it will break something.
1997 Jeep Cherokee Sport (XJ) (Engine: 4.0L - I6) (2WD)
My Feedback Thread
<--- Just a dumpster on fire
Old 12-05-2018, 09:25 PM   #2
bobxyz
bobxyz's Avatar
Are you talking about the big plastic panel to the left of the driver's feet?
On my '85, there's a fresh air vent and lever in the center of it. To remove panel, pull off the rubber knob from fresh air vent lever, remove rubber U-channel from front side of door opening, and you ?may? need to remove the plastic door sill protector - it pops upwards and is held on with little metal trim clips. No force should be needed once the other stuff is removed.
Old 12-05-2018, 10:07 PM   #3
smeha
Tranny Whisperer
smeha's Avatar
Door side(by the fuse) is removed.
I don't have a vent itself(removed after certain year but the grill opening in plastic stayed).
So something holding it in the middle or far down the footwell.
Old 12-05-2018, 10:27 PM   #4
Pull the plastic pin and it'll come off.
Old 12-05-2018, 11:38 PM   #5
smeha
Tranny Whisperer
smeha's Avatar
So give it a good strong rip, got it.
Old 12-05-2018, 11:40 PM   #6
Old 12-06-2018, 01:38 PM   #7
300+hp on the shelf club
That tool will save you much grief when pulling plastic pins like the one in the panel.
