Old 03-31-2006, 12:11 AM   #1
shutterlug
Default Splash pan...worth it?
Does anyone have any experience with the splash pan ipd sells? Is it worth it? Good investment? Waste of time and money?
Josh
shutterlug is offline   Reply With Quote
Old 03-31-2006, 12:46 AM   #2
stylngle2003
stylngle2003's Avatar
splash pan, or aluminum sump guard?
the splash pan is very beneficial...keeps your belts dry and the front oft he engine nice and clean
-Billy
1990 Mazda Miata (track toy)
Old 03-31-2006, 02:02 AM   #3
volvogeek
They're good for keeping the alternator nice and dry when you play the Puddle Game(tm).
*puddle game - finding the deepest spot of a puddle and driving through it at speed to see how big of a splash you can make without hydroplaning into oncoming traffic
volvogeek is offline   Reply With Quote
Old 03-31-2006, 02:08 AM   #4
stylngle2003
you win when the lights flicker and the belts squeal
Old 03-31-2006, 08:48 AM   #5
karmaticlove
Guest
^^^^^ classic ^^^^^ :-)
Old 03-31-2006, 08:48 AM   #6
karmaticlove
Guest
The IpDs are super aesthetic, seem to be very nice quality... if I had a couple of buck to burn... one would be on my car ASAP.
However, I bought an ABS plastic one that has been on my car for 3 years... no problems... in fact, I agree, it keeps everything nice and tidy & dry.
It not only protects the belts but the lower steering knuckle too.
Old 03-31-2006, 12:30 PM   #7
taskmule
this space for rent
taskmule's Avatar
Default splash pan?
And the pan catches sockets and bolts that you drop during playtime...
'mule
____________________________________________
White 97 855R 96k miles
taskmule is offline   Reply With Quote
Old 03-31-2006, 02:38 PM   #8
tjts1
tjts1's Avatar
Yeah... good luck getting them out of there without droping the pan.
Greed is good.
tits for president
tjts1 is offline   Reply With Quote
Old 03-31-2006, 03:08 PM   #9
boostdemon
creative mastermind
boostdemon's Avatar
us 4cyl people dont have any problems lol
"Flathood" Owners | Motorcyclists | Guitarists
boostdemon is online now   Reply With Quote
Old 03-31-2006, 04:41 PM   #10
ovlov760
ovlov760's Avatar
I can usually just reach down into the engine bay and retrieve my tools.
The splash pan is also suppose to help the aerodynamics of the car.
ovlov760 is online now   Reply With Quote
Old 03-31-2006, 04:59 PM   #11
taskmule
this space for rent
taskmule's Avatar
I have very good luck just reaching down and picking them up, thanks. That's one of the reasons the pan is there. Yup.
Old 02-28-2014, 03:45 PM   #12
oldschoolvolvo
oldschoolvolvo's Avatar
Pardon the old thread bump...but does anyone know the size of the bolts for the splash pan? I am putting one on my 240 and all the bolts have gone missing.
-Mike
1998 V70 T5
|Feedback|
Old 02-28-2014, 03:47 PM   #13
6x1x 25 or better, don't forget the fender washers...
Old 02-28-2014, 03:57 PM   #14
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
6x1.25 if jimbo didn't impact drive a sheetmetal screw in there that has now rusted and fubared everything.
The OE plastic one seals a lot better than the IPD around the rack boots and generally. If you can find a good condition metal early one and block off the vents, you are basically set (profile of the plastic one, but made of steel).
How PSI a stock can support?
Always Be Crushing!
Old 02-28-2014, 05:54 PM   #15
vxracer
vxracer's Avatar
I'm probably gonna have to drop the dough on an ipd s90 splash shield. Pick n pull has 0 7xx or 9xx series ones. I got lucky on my 244 and got 1 there. I could tell it was under at high rates of speed. On this s90 I think its more of a cooling airflow through the radiator effect. My electric fan comes on quite a bit and its not even hot yet. Yikes!
vxracer is offline   Reply With Quote
Old 02-28-2014, 06:15 PM   #16
fortbrick
fortbrick's Avatar
I went from cleaning the engine bay 4-5 times a year to just once a year after I added mine.
Old 02-28-2014, 06:26 PM   #17
Kjets On a Plane
Devoid of Luxury
Makes a big difference in airflow, how long the belts and accessory bearings and timing idler bearing lasts. Abrasives and corrosives being flung all around doesn't do anyone any good. Anyone have the joy of taking an engine out of an 84 and earlier 240 because the York clutch sticks on and the York rattles so bad trying to compress old nasty refrigerant that it shears all 4 mounting studs off in the block? Easier to keep dirt out of the bearing, and tension the belt right...
This said it shouldn't be night and day for how often the fan runs, I'd keep looking if it isn't very warm out. 960 has 2 coolant sensors and they do go bad, maybe a bubble or a seeping hg or something. Clogged up rad, sheared water pump impeller or shot water pump bearing, or radiator full of dirt are all common enough. Happy hunting!
The cheapie plastic ones aren't that terrible as may be more viable than a used one.
Old 02-28-2014, 07:14 PM   #18
ellist
A splash pan is worth it. The difference they make on the condition of the engine bay is immediate. Your altenator will last longer too. Buy one, bolt it up and enjoy the positive impacts.
ellist is offline   Reply With Quote
Old 02-28-2014, 11:03 PM   #19
volvorod85
volvorod85's Avatar
I keep em on cause if I go through a puddle or it rains you loose the alternator and power steering in a redblock car
1995 E320 wagon AMG 3.6 swap <-- Daily driver
2009 Honda Fit <-- Wifeys ride
1959 Austin Healey Sprite <--something completely different (my project)
1974 Fiat X1/9 <--Mom's little toy (next project)
1982 Olds Custom Cruiser LQ4 <--Dad's beast (current project)
"Driving the old 2 valve 740 is a bit like driving an IKEA wall unit, so leisurely is its acceleration, so angular its lines."
My former brick saved my life 6/25/03....Volvo for Life
volvorod85 is offline   Reply With Quote
Old 02-28-2014, 11:20 PM   #20
Z33_Taxi
Z33_Taxi's Avatar
Originally Posted by ellist View Post
A splash pan is worth it. The difference they make on the condition of the engine bay is immediate. Your alternator will last longer too. Buy one, bolt it up and enjoy the positive impacts.
I'm dealing with that issue currently. Volvo champ is all this snow, but I feel my alternator took all the pain.
Z33_Taxi is offline   Reply With Quote
Old 02-28-2014, 11:25 PM   #21
Mr. V
Mr. V's Avatar
Pretty easy to do when you use your Magic Wand.
Old 03-01-2014, 12:19 AM   #22
ellist
Yeah I learned my lesson on the 2nd 240 I ever owned. I went through several alternators before figuring it out. The kick up from the road also put a lot of wear and tear on the wires that run from the alternator to the driver's side of the car.
Even if you get an inexpensive one like this, http://www.eeuroparts.com/Parts/4279...#axzz2ugHC0hNN , you'll be doing yourself a service. The price is so low that you may find it worth while to snag one of these new ones instead of salvaging one. I bought one of those URO brands years ago and it has held up great. Very thick. A pain to line up. I wound up cutting slots for the holes so I could shift it around for fit. I also bought my own bolts/washers for mounting. Went with a nice wide washer and a length about 5mm shorter than what is usually sold as "belly pan mounting bolts".
Old 03-01-2014, 08:35 PM   #23
brian smith
This is the right size, the 6 x 1.25 recommendation is bunk.
My practice was to install studs for the rear 3 locations, slightly filing the slots in the pan for easy insertion, then using M6x1 stainless bolts for the front locations. One hand locates the pan on the 3 studs, the other threads a front bolt or two in, less chance of cross-threading a relatively fine-thread fastener.
Fender washers recommendation seconded, and I used stainless lockwashers as well.
Soon I'll be wearing a belt and suspenders...
MSCDirect.com for the stainless 6x1 threaded rod and "heavy" nuts to make your own long studs for the rear locations. Works "a treat."
Old 03-01-2014, 08:38 PM   #24
Z33_Taxi
Z33_Taxi's Avatar
I'll most likely try my local PnP. If I come up empty handed I'll just get the IPD one
edit: I wonder if it would be beneficial to hit a cheap plastic one with some bedliner to toughen it up. I'm sure the the right hardware it would hold
Old 03-01-2014, 09:23 PM   #25
TestPoint
TestPoint's Avatar
The RockAuto ABS shields are dirt cheap but the shipping will kill you.
Ford V8 Conversion Manual -
