Old 03-01-2014, 09:40 PM   #26
Z33_Taxi
Z33_Taxi's Avatar
ugh rockauto and their shipping
Z33_Taxi is offline   Reply With Quote
Old 03-02-2014, 12:29 AM   #27
coonmanx
Originally Posted by stylngle2003 View Post
you win when the lights flicker and the belts squeal
I remember last year when it was flooding here a lot. On the way home one day traffic was all messed up because the streets had a lot of water on them. I took the right lane to get around a few folks and then saw the voltmeter dip down and heard the belts squeal. But I did make it home at least. That splash pan might just have helped.
Jim C.
Don't own a Brick anymore. It got crushed.
coonmanx is offline   Reply With Quote
Old 03-02-2014, 05:52 AM   #28
Z33_Taxi
Z33_Taxi's Avatar
Ordered the IPD pan. All these horror stories
Now how to make a blank pan pretty
Old 03-02-2014, 10:21 AM   #29
Kestrel
Kestrel's Avatar
http://www.eeuroparts.com/Parts/4279...#axzz2uoaak41h
$19, $9 more to ship.
Even TB can afford that.
Old 03-02-2014, 11:35 AM   #30
TestPoint
TestPoint's Avatar
Great price, $28! RockAuto's total was about $43. Ordered it.
Ford V8 Conversion Manual -
Old 03-02-2014, 01:28 PM   #31
Mr. V
Mr. V's Avatar
Another benefit of using a splash pan is that you can tell by glancing at the top of the pan whether coolant (or other fluids, god help you) are leaking out of the front of the engine compartment.
Typically a quick look gives me early warning that I have a weeping water pump or radiator issue.
Old 03-02-2014, 03:32 PM   #32
Z33_Taxi
Z33_Taxi's Avatar
With the IPD pan I think I'm going to put some sound deadner on the inside. I can only imagine how loud it'll be
Old 03-02-2014, 03:40 PM   #33
I don't hear mine, but I did screw a 6" x 6" piece of 1/2" plywood to the back of it between it and the crossmember, so I can jack the car up by the tail of it without bending it.
Old 03-02-2014, 03:51 PM   #34
JohnLane
I've seen them on cars... You won't notice the difference.
Old 03-02-2014, 03:56 PM   #35
badvlvo
Bad for Babies
badvlvo's Avatar
Why would it be loud?
I've had a few of them, never noticed it making any noise.
Died at age 35
Old 03-06-2014, 02:53 PM   #36
Z33_Taxi
Z33_Taxi's Avatar
I just figured the stainless might intensify engine noise
Hello beautiful :D
Old 03-06-2014, 03:43 PM   #37
cleanflametrap
cleanflametrap's Avatar
Originally Posted by brian smith View Post
This is the right size, the 6 x 1.25 recommendation is bunk.
My practice was to install studs for the rear 3 locations, slightly filing the slots in the pan for easy insertion, then using M6x1 stainless bolts for the front locations. One hand locates the pan on the 3 studs, the other threads a front bolt or two in, less chance of cross-threading a relatively fine-thread fastener.
Fender washers recommendation seconded, and I used stainless lockwashers as well.
Soon I'll be wearing a belt and suspenders...
MSCDirect.com for the stainless 6x1 threaded rod and "heavy" nuts to make your own long studs for the rear locations. Works "a treat."
I kinda like this idea. Have you ever ripped a chunk out of your scalp or shoulder on one of these slipping under the crossmember with the pan off? Or do you have a lift to work under?
-Art
Old 03-06-2014, 03:56 PM   #38
Hello beautiful :D
It's aluminum.
Old 03-06-2014, 08:59 PM   #39
brian smith
Default not yet
No lift here, and it's only been this way for 6 months or so, but you can choose how far down you want the studs to extend...I bought 3' of stainless threaded rod from MSC, cut thrice after measuring once, and the studs only have to manage a nut, a stainless fender washer, and the thickness of the pan...If you reinstalled the bolts just to not lose them after removing the pan, they'd probably hang down the same amount. You could make them even longer, cap them with rubber caps, then reinstall the rubber caps when the pan is removed for the true safety zealot.
Old 03-06-2014, 09:12 PM   #40
Z33_Taxi
Z33_Taxi's Avatar
It's aluminum.
So it is.
I am going to put something on the inside of the IPD logo. Idk why they didnt laser etch,but that just a place for dirty and grime to pass through.
Something like this,found on swedespeed.
Old 03-06-2014, 09:33 PM   #41
brickyard92
Regular Contributor
brickyard92's Avatar
Splash pans are more for aerodynamics than anything else.It does affect your mileage very slightly at highway speeds.That stainless one looks awesome.
brickyard92 is offline   Reply With Quote
Old 03-07-2014, 01:16 PM   #42
mafoose
Boost Addict
mafoose's Avatar
It's aluminum.
Yay reading!
I wish the IPD one had provisions for oil drainage from the filter.
- 84 242 - 92 740 - 72 240z - 78 280z -
mafoose is offline   Reply With Quote
Old 03-07-2014, 01:20 PM   #43
atrokz
super cage design genius
atrokz's Avatar
So it is.
Much more cost effective to cut it out when it's being plasma/water/laser cut vs moving it to another machine. Just rivet or screw a piece of colored plastic behind it.
'06 BMW E91 3.0 DD
91 945 SE - Modded the turbobrick way
98 BMW E36 2.8 - Wife's car
92 245 DL WAS NOT TO BE -RETURNED FOR ZERO SPACE
91 745T RIP
94 850 NA RIP
95 850R GONE
Rob Ford was Canadas greatest president
atrokz is offline   Reply With Quote
Old 03-08-2014, 04:33 AM   #44
perko
For those not wanting to pay for the ipd ones, i have one on mine just bent up out of some thin gauge aluminium in pretty much the same shape, then a couple of old rubber floor mats cut up to protect at the sides, seems to work pretty well
perko is offline   Reply With Quote
Old 03-11-2014, 02:25 PM   #45
artca
splash pan=good.
before I had installed one on my 740 the engine was ALWAYS gettin dirty and dusty...now it just gets dusty.
got it from locally- about $22.00
artca is offline   Reply With Quote
Old 03-11-2014, 03:02 PM   #46
atomicthumbs
atomicthumbs's Avatar
The splash pan has one major disadvantage: it makes it more difficult to stand inside the engine bay of your car.
Pro imgur tip: add "l" to the end of the image ID (bvcTR9s in your case) and it'll automatically give you a shrunken version to fit forums
atomicthumbs is offline   Reply With Quote
Old 03-11-2014, 03:31 PM   #47
grnmachine02
Indicating?
grnmachine02's Avatar
Actually, according to Volvo it's main purpose is cooling. Something about how it directs airflow around the engine bay.
1990 745t- b230ft, ebay manifold, hy35, Microsquirt, t5 2jz and w58 eventually no engine, and a decent mold collection on the interior.
Rage boner achieved.
grnmachine02 is offline   Reply With Quote
Old 03-11-2014, 04:43 PM   #48
A tough rowing ho
It also gives you a place to zip tie in an engine diaper for all those leaks one can't find.
Me for President
First candidacy driven entirely by smart phone.
Campaign slogan
"Trump, I wouldn't piss on him if he were on fire!"
Old 12-04-2018, 05:04 PM   #49
iHateVolvoPeople
Lord_Athlons daddy
What is everyone's experience with iPd's plastic 740 ( ) tray? Need one for the '90 744. Don't wanna pay RockAuto shipping.
https://www.ipdusa.com/products/5500...40-960-s90-v90
Feedback Thread
Current:
93' 244T M47
93' 245 M47
90' 744 AW70
90' 745 AW70
94' M-Edition Miata 5 speed, 93k
95' Camry A140E, 246k
91' 745 Regina AW701, maybe future turbo project
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
Old 12-04-2018, 09:55 PM   #50
2turbotoys
Salaminizer
2turbotoys's Avatar
You want a good used one? I have one, sell it to you really cheap. Its a factory Volvo part as well if I remember correctly. PM me
1978 242, getting prepped for LS
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
