BDKR
Section 9
- Nov 16, 2003
- Horizons Cave
I can't say just how much I am completely floored by your efforts. You are quickly becoming a legend here.
the poi said:I'm probably burning through oil now seeing as I love keeping the big sewing machine at atleast 3 grand .
my original fear that everything was gonna break kinda bit me in the ass in that regard I used a (much) cheaper basic stamp 1, which only has 8 i/o pins. I onyl have two left as it stands, so not enoguh to control a gear display If I get around to doing my new guage cluster before I have an MS-II solution set up, then I'll just get a BS2 with its 16 i/o pins, and strap it up to a 7 segment display. that oughta look rockinThe Aspirator said:I was thinkin maybe you could make a little LED panel with numbered faces to show you what gear you're in, that would be sweet! It should be do-able right? Since the controller knows what gear you're in, could you just have another output to power the proper LED?
I was watching that old yahoo megashift forum for a while now, never saw any progress on anything. I'm really glad that you took control and actually DID it.
John
the stock aw30-40LE in the 960 yes. and it won't work for a 760 or anything with a fully mechnical transmission doesnt mean you cant try to retrofit a aw30-40 to the redblock though, hehturboluv said:ok 1st of all: holy ****ing **** goddamn, that is the coolest ****ing thing i've seen in recent history.
secondly: i skimmed the original write up like 4 times now, (if i try to read it all the electrical mumbo jumbo makes my eyes cross and i involuntarily reach for some sort of bottle...) and i still cant find what tranny you are using for this...is it just the factory 960 tranny?
and will this ever work in a 760?
the poi said:doesnt mean you cant try to retrofit a aw30-40 to a redblock tho, heh
heee. compare some pictures of both, theres some whispers floating around that you could put the aw71 bellhousing on the aw30-40, but my foggy memory of the aw71's bell makes me think it isnt that easy....turboluv said:i take that as a subtle way of saying thats a difficult task? this coming from somebody who figured out how to put paddle shifters on a volvo is somewhat disheartening
the poi said:my original fear that everything was gonna break kinda bit me in the ass in that regard I used a (much) cheaper basic stamp 1, which only has 8 i/o pins. I onyl have two left as it stands, so not enoguh to control a gear display If I get around to doing my new guage cluster before I have an MS-II solution set up, then I'll just get a BS2 with its 16 i/o pins, and strap it up to a 7 segment display. that oughta look rockin
740TurboPerformance said:To quote Jeremy Clarkson "uggggh, floppy gear box" (freakin' floppy paddles) . . . .
coldfusion21 said:how different is the aw30-40 from an 4l60e? as in if i built your basic stamp, would it control a 4l60e, or are most e trannys different?
