![]() Manual pedal box swap for cable clutch into 1990 740. I got the box into the correct position, but the top left bolt doesn't line up. It looks like the bolt for the clutch pedal is rubbing against the piece of metal on the left. Does this piece get removed and attached to to the new pedal box? I'm not exactly sure.
![]() Yes you have to remove the rivets, some models come with a removable slider those are easily interchanged, this will require new rivets
Volvo 745 - IPD springs, 25mm/19mm swaybars, K-cam, LH2.4, M90 swap, 3.54 \w racingdiff lsd, track/daily -------------------------------------------------------------------------------------------------------------------------- I sell LH2.4 Chips for Europe! |
![]() Typical 30-minute job turning into a 3-hour job and extra money! I'll probably try to use something else than rivets because I don't have rivets or a rivet gun. This will probably be ok right?
#4 |
Benchracer Tribe
![]() A bolt + nut + lockwasher would be what I would use
"you can't leave your thingy hanging in public... you can get arrested." "What's Arkansas supposed to be, Kansas for pirates?" Forg "I think I can touch the tire. Damn! I can touch the tire! That hurts!" 240Psycho (on the back seat of my 94 Jetta while I was driving to a J/Y) "Use the barbed adapter like what I use to inflate the air camping mattresses and my dates." FTF Engineering i am inspired. i will replace my windsheild... with an intercooler.swedishK Feedback! |
