Old 10-12-2020, 08:59 PM   #1
2 old for this
Default Abs- speedo wiring
88 740. I cant find a legible diagram for the ABS. There are 3 wires coming from the converter. Where does the white one end up? Been away from this project to long and memory has faded.
Old 10-12-2020, 09:47 PM   #2
Old 10-13-2020, 06:51 PM   #3
2 old for this
Thank you for your reply but it doesn’t answer my question.There are 3 wires that go to the converter.Green brown white. Where does the white wire end up ? The shielded wire must have been omitted in production.
Old 10-13-2020, 07:13 PM   #4
bobxyz
bobxyz's Avatar
If it's the same as "TP31058_1 1987 740 760 Wiring Diagrams" pg80, then:
- white goes through a connector to green/white wire off of the speedometer connector
- blue/red is power (ign sw 15R)
- green/white and brown go to the sensor "abs speedometer transmitter" and the abs control unit
Old 10-14-2020, 07:12 PM   #5
lummert
lummert's Avatar
Mitchell wiring diagrams are readable.
White wire on my 88 765 goes to the speedometer.
There may also be blue-red wires, as well as green-white, and blue-white wires.
Old 10-14-2020, 07:44 PM   #6
2 old for this
Thank you both for the answers. Hopefully I can get this project completed this weekend.
