Old 10-14-2020, 05:09 PM   #1
Shinchan
Default T5 swap: How much tunnel clearance for a slip yoke?
Finally getting things where I need to to measure for the length of the front driveshaft for my T5 swap in my 142. Unfortunately I wasn't paying attention and the T5 slip yoke that I got is a 1330 instead of a 1310. The yoke rotates freely, and at the tightest point of the rotation it comes within about 3/16-1/4" of the tunnel. Is this enough clearance, or am I going to have to bite the bullet and buy another $80 slip yoke?
Shinchan is offline   Reply With Quote
Old 10-14-2020, 05:42 PM   #2
Just run it
Old 10-15-2020, 12:23 PM   #3
Benjam83
Moar Volvos than Queen B
Kind of on-topic....If you switch slip-yokes, do you need to have the DS re-balanced?
Ben
12 WRX Hatchback
10 Subaru Outback
93 245 m47
Benjam83 is offline   Reply With Quote
Old 10-19-2020, 10:30 AM   #4
Shinchan
Most shops don't balance with the slipyoke, so I would assume not.
Old 10-19-2020, 10:33 AM   #5
JohnMc
JohnMc's Avatar
Just run it. It will self-clearance as needed.
But srsly, it sort of depends on your trans mount, and to a lesser amount your engine mounts - how much they let the trans end wiggle around.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 10-19-2020, 11:03 AM   #6
Shinchan
heavy-duty engine mounts, and a firm poly trans mount to a solid cross-member.
The mount is pretty close to the tail of the trans. I'm going to run it and see what happens.
If I have clearance issues then I'll swap out the slip.
Old 10-19-2020, 11:23 AM   #7
JohnMc
JohnMc's Avatar
I initially ran my T5 on a stock mount (chunk of angle iron between it and the T5) and that was pretty wiggly. Then I used a Yoshifab crossmember and a solid poly T5 mount, far, far less wiggling around with that.
Old 10-20-2020, 11:01 AM   #8
Benjam83
I've got the same Yoshifab setup, and just a regular slip-yoke. I've got a few little odds&ends that I need to wrap up, but I think it should be drivable the next time I get over there to work on it.
Old 10-23-2020, 10:51 AM   #9
Shinchan
Got the car moving under its own power last night, and so far no sign of the yoke rubbing on the tunnel.
Old 10-23-2020, 10:32 PM   #10
vertigosity
vertigosity's Avatar
When I did the T5 swap in my '80 16VT, I started out with a 1330 U-joint yoke driveshaft that came with my transmission (SN95 V6), and it definitely made contact with the body under load with a stock Mustang style rubber transmission mount - but was fine under daily/street conditions. A 1310 was fine in it, as well as on the similarly-placed TKO on my '93 LSx car.
93 245 5.3L LSx / 90 Miata / 90 Spec Miata
Old 10-25-2020, 09:58 PM   #11
Benjam83
So, I just got my swap on the road for the first time last night. It's just got the regular style slip-yoke. One of my big concerns in this endeavor has been all of the talk around vibrations and noise.
All I did was eye-ball the driveshaft alignment. I was just trying to make it drivable. Took it for a couple test drives, about 20 minutes total. So far, it's great. I mean, the whole reason for the swap was the issue with m47s bearing deteriorating and being noisy in 3rd and 5th. At this point, I'd call this is a success in my book...
