Old 10-15-2020, 10:21 AM   #1
RickATL
Family's fleet manager
RickATL's Avatar
Default bypassing dash dimmer
I have read several times in threads about how bypassing the dimmer will make the dash lights brighter. I tried making a wire with prongs to connect the two. It didn't work, so I clipped the wires and tried just running them together. Does it need to be wired some special way?
Currently 91 245 "Ingrid," 93 244 "Lars," and 92 245 "Astrid"
Past
88 245 "Margit" sold
93 244 completely disassembled - It died, so many of its parts could help others live.
97 855 T5
97 855 NA
RickATL is offline   Reply With Quote
Old 10-16-2020, 11:27 PM   #2
RickATL
RickATL's Avatar
Crickets
Old 10-17-2020, 12:27 AM   #3
Default Splicing wires
Last edited by ZVOLV; 10-17-2020 at 12:41 AM.. Reason: thought the question was about splicing wires
Old 10-17-2020, 12:39 AM   #4
RickATL
RickATL's Avatar
Thanks for the info, im also wondering if both the red/whites connected to both the browns or are they supposed to be individually seperated.
Old 10-17-2020, 12:41 AM   #5
The Librarian
Connect all 4 wires together to bypass the dimmer.
Old 10-17-2020, 12:45 AM   #6
How should all 4 wires be connected together?
Old 10-17-2020, 01:00 AM   #7
The Librarian
Replace the blade connectors and use one of these.
Old 10-17-2020, 11:37 AM   #8
VolvoScout
Can anyone confirm that bypassing the dimmer makes the dash lights brighter?
I've been having trouble seeing my dash at night as more cars with Xenon and LED lights are on the road.
Old 10-17-2020, 05:48 PM   #9
RickATL
RickATL's Avatar
Do you have a link to something like that? I don't know what it's called or where to start.
Old 10-17-2020, 06:06 PM   #10
The Librarian
I believe they're used on air cooled VW's.
https://www.ebay.com/i/233422578711?...hoCx7AQAvD_BwE
Old 10-17-2020, 06:37 PM   #11
philski o'flood
philski o'flood's Avatar
wire nuts
philski o'flood is offline   Reply With Quote
Old 10-17-2020, 06:41 PM   #12
Question
Flux, solder, and heat shrink tubing.
Old 10-17-2020, 11:11 PM   #13
philski o'flood
not the easiest location for all that... which is why... Wire Nuts
Old 10-18-2020, 01:20 AM   #14
MasterBlaster
Power comes in on grey from fuse 16.
Red/white takes full power to seat belts + ashtray.
Brown #1 (dimmed) goes to radio display.
Brown #2 (dimmed) goes to the (auto) shifter, panel lights, and gauges.
As stated, connect them all together using your favorite technique.
They will be as bright as they "can" be.
air cooled VW's. (Wire Block Connector)
wire nuts
I believe the TB "correct" way is with a square knot (or a granny knot if you're in a hurry), wrapped in several layers of Xmas-themed Scotch tape.
504,000 km so far...
Old 10-18-2020, 05:40 AM   #15
F*ck 12
Just twist them together and 2 wraps of black tape should do it.
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 10-18-2020, 10:17 PM   #16
2turbotoys
Astro Zombie
2turbotoys's Avatar
Ok, get 2 male spade terminals, connect them with a short length of wire. Unplug the dimmer, connect the 2 leads using your new patch cord. Insulate them with heat shrink tubing, or electrical tape if you must. Please don't use a wire nut. Not for use in a car. Electrical tape doesn't withstand time that well and will eventually start to unravel.
You do not need to be hooked to the dimmer switch at all.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 10-21-2020, 10:59 PM   #17
RickATL
RickATL's Avatar
Default Final report
Thanks. I did it like you said here and it worked now. As to whether it's brighter?.... Maybe 20% total. It will have to be good enough until I figure out how to to put LEDs there. I ordered a set and I don't see how they will fit in to the bulb bases in the dash console.
Old 10-22-2020, 08:20 PM   #18
2turbotoys
Astro Zombie
2turbotoys's Avatar
What is the voltage there? It should be just over 14V with the car running. If not, something might be on the circuit that is using a lot of power or the ground isn't in good condition.
Old 10-27-2020, 05:56 PM   #19
hessam69
Where do you probe to measure the voltage when talking about the cluster lighting?
