Old 10-17-2020, 12:36 PM   #1
8587turbo
Default B234 head/cam carrier anaerobic sealer
In near future I'll be putting the cam carrier onto the head & would like to find out if using Permatex Gasket Making Compound 51813 is a good choice for this job ? Or is there a better anaerobic Gasket Maker ? No VOLVO dealers within 4 hrs drive. Thanks
8587turbo is offline   Reply With Quote
Old 10-17-2020, 12:52 PM   #2
The trick for me has been to use a short bristle roller to apply it. If you apply too much it will block oil passages.
Old 10-17-2020, 01:43 PM   #3
oldschoolvolvo
oldschoolvolvo's Avatar
^good advice & Loctite 510
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 10-17-2020, 06:48 PM   #4
hessam69
Don't get it in the cam bearing surfaces or else it will lock the cam up once it cures
hessam69 is online now   Reply With Quote
Old 10-17-2020, 07:02 PM   #5
white855T
Order Volvo sealer from fcp. Just add a couple of small things you'll be over $49 for free shipping.
Old 10-18-2020, 09:49 AM   #6
JohnMc
JohnMc's Avatar
I'm not sure what IPD sells as a replacement. *checking IPD site*
IIRC it was something else other than this stuff?
https://www.ipdusa.com/products/1143...71200-30644517
Dunno, but I had the head on and off my 16VT motor more than I liked (ahem) and always meticulously cleaned and prepped the surface with rubbing alcohol so it was shiny, spotless, and dry. And used the $40 Volvo sealer maybe 2 times and it was always dry. Used the IPD stuff one single time - exact same procedure, and had a modest amount of seepage along the outside edges. So I went back to the OEM Volvo pink stuff and it was dry again the next few times I did it.
YMMV, etc.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 10-18-2020, 11:45 PM   #7
8587turbo
Did some research & found this on matthews volvo site. Its a 3 page thread but worth reading.
LOCTITE 518 is less than $10. on Ebay
https://www.matthewsvolvosite.com/fo...iewtopic.php?f
Post by ThommyKent » Fri Jan 03, 2020 4:06 am
The Volvo anaerobic is made by Loctite.
If you look on the Safety Data Sheet for Loctite 518 it says this:
2. HAZARDS IDENTIFICATION
LOCTITE 518 IND 6ML
2096062 2096062 United States
Anaerobic Adhesive None identified
If you look at the Safety Data Sheet for the Volvo anaerobic it says this:
Anaerobic Gasket Maker 518
495539 37530
United States
Notice the Volvo is described as Anaerobic Gasket Maker 518 meaning it is Loctite 518
They are both manufactured by Henkel AG of Germany
The Permatex will work just fine as it is 518 also, but they do not manufacture the Volvo
