Old 10-18-2020, 10:39 PM   #1
Frank_Rizzo
Default How to replace front emblem decal on 1984 Volvo?
Recently I purchased a replacement emblem, 70mm. It's just a sticky decal. How do I get this thing inside the casing on the grille? I assume you'd have to somehow open the casing, scrape off the disintegrated original emblem and stick the new one on, and re-assemble it?
How do you do this exactly? I can't find anything on the internet.
Frank_Rizzo is offline   Reply With Quote
Old 10-18-2020, 10:47 PM   #2
Murploid1
Murploid1's Avatar
I recently also purchased a replacement emblem for my grill. My car is an 82 and I (stupidly) didn’t measure it- 70mm is too big. So, had to order a replacement smaller badge ugh...
Anyhow, I used a trim tool and a pick to pry the old emblem out, it’s glued in place. Persist and it will come out. I plan on using some sort of flexible adhesive to secure it. Just clean all the old adhesive out. Mine is prepped and ready to be glued when it arrives. I was going to use double sided tape but this will not allow it to sit flush.
Murploid1 is offline   Reply With Quote
Old 10-18-2020, 10:53 PM   #3
Frank_Rizzo
Originally Posted by Murploid1 View Post
I recently also purchased a replacement emblem for my grill. My car is an 82 and I (stupidly) didnít measure it- 70mm is too big. So, had to order a replacement smaller badge ugh...
Anyhow, I used a trim tool and a pick to pry the old emblem out, itís glued in place. Persist and it will come out. I plan on using some sort of flexible adhesive to secure it. Just clean all the old adhesive out. Mine is prepped and ready to be glued when it arrives. I was going to use double sided tape but this will not allow it to sit flush.
Wait, I think mine was 65mm, I must have misspoken. 70mm is for 1986-1993, I believe.
Anyway, that gets at the crux of the issue. Exactly how did you get the old emblem out in the first place? It's encased in a space covered by acrylic in the front, metal in the back, affixed to the grille.
Old 10-18-2020, 10:54 PM   #4
Wipe the old rondel with acetone or lacquer thinner let it dry, and put the new one right on top of the original.
how psi stock cna sprout?
Old 10-18-2020, 10:55 PM   #5
white855T
The emblem is not glued in place. The emblem is applied with double sided tape. If you are using a genuine Volvo emblem, you must use double sided tape. Do no use adhesive, it will ruin the emblem(ask me how I know). If you are using a decal it can be applied over the original emblem.
Old 10-19-2020, 09:05 AM   #6
Murploid1
Murploid1's Avatar
Like I said use a trim tool, pick, or small flat head screwdriver to pry it up, work it and it pops out.
White855t is correct regarding adhesive if you have a genuine emblem - they have foil paper on the back. Looks like I will be buying some thinner double sided tape..
Old 10-19-2020, 10:17 AM   #7
TestPoint
TestPoint's Avatar
My acrylic cover is in bad shape from a couple hundred thou miles of road sandblasting and rock chips.
Pretty obvious that it cannot be polished out like a headlight lens.
Under cover would certainly seem to be a preferred solution and I might try to pry the old plastic and cut and polish a replacement
Maybe Dave Barton will comment.
Ford V8 Conversion Manual -
Old 10-23-2020, 09:51 PM   #8
dbarton
Dejected by Volvo Corp.
dbarton's Avatar
A photo of this thing the OP bought would be useful.
Dave B
'84 242ti, fourth owner, mine since 2003. Always garaged since brand new. Old-school rounds because I like. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with modded 0.73 OD, 3.91 diff, unmodified G80.
