Old 10-18-2020, 11:13 PM   #1
howlett10
Default Will new struts make my suspension stiff?
So, 6 months ago I finally was able to purchase a Volvo 240 after months of trying to find one in decent shape, almost immediately I cut all of the coilsprings, 3 coils on every spring. I know, this is a stupid way to lower a car and heavily frowned upon. I had intentions on buying coilovers in the summer but I lost my job due to good ol COVID so those plans came to a halt, now that it's getting very cold where I live I want to make my suspension as best I can so I don't run into any problems throughout these next 7ish VERY cold months, the front end of my car is crazy bouncy, every pothole or bump my car will just bounce and honestly it doesn't feel good at all, annoying honestly. So today I purchased a set of struts with hopes that they'll stiffen up the front end with my cut springs, is this possible? I had my car on a lift yesterday and my struts did look pretty worn out in all honesty.
howlett10 is offline   Reply With Quote
Old 10-18-2020, 11:15 PM   #2
white855T
Get some stock springs and install new struts. Then when you can properly spend some money, do it right with coilovers.
Old 10-18-2020, 11:16 PM   #3
No.
You drank the kewl-aide, now pay the price.
Old 10-18-2020, 11:40 PM   #4
2turbotoys
Astro Zombie
2turbotoys's Avatar
Springs are cheap, put new ones back in there, or good used ones.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 10-18-2020, 11:47 PM   #5
Cheaper than getting pitched into the ditch and wadded up on the snowbank.
Old 10-19-2020, 02:39 PM   #6
Get a set of non ****ed stock springs. Run them until your financial situation improves.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 10-19-2020, 02:46 PM   #7
Fa182
Stage 1
Fa182's Avatar
The spring rate is all messed up now if you cut 3 coils, so you will never get rid of the bounce even with new shocks.
Old 10-19-2020, 05:17 PM   #8
redblockpowered
redblockpowered's Avatar
Not stiff enough.
I sell chips for LH 2.4!
Old 10-26-2020, 03:41 AM   #9
SkeTchy-MechAniC
SkeTchy-MechAniC's Avatar
I bought my 4 lowering springs for 90eur new.
Never have i ever .... Seen a 242 with two motorcycles in the back
SkeTchy-MechAniC is offline   Reply With Quote
Old 10-26-2020, 11:22 AM   #10
Marvelous3
Who engineered this?
Marvelous3's Avatar
Not necessarily but they can.
Old 10-26-2020, 06:48 PM   #11
klr142
Turbo, what?
klr142's Avatar
Yes and no. It'll IMPROVE your ride quality over larger bumps and reduce your bouncing, BUT, you will still be bottoming out your suspension with regularity and causing the crap ride quality and initial bounce. If your car keeps bouncing after the initial hit, that's because the struts and/or shocks are blown. Your initial impact and crap ride quality comes from not having suspension travel and/or not having sufficient stiffness to prevent you from hitting the limits of your travel(or bump stops, if they exist anymore).
Yes, and no. If his problem is blown struts, his bouncing will be greatly reduced with a good set of struts. The problem is, he is likely also bottoming out the suspension and that is going to create an initial impact harshness that will not disappear with good struts that will dampen the resulting bounce back up from bottoming out.
What struts did you buy? Your struts can't "look pretty worn out" unless they're leaking fluid. Otherwise, their internals that wear are hidden from your view.
Your ride will likely improve with new struts, but it will still be far from ideal and you will still crash hard over larger bumps and potholes. The continued bouncing after an initial impact will be reduced, though.
Old 10-28-2020, 07:48 PM   #12
daijoubanai
waste of skin and blood
daijoubanai's Avatar
Did you buy just standard replacement struts? If the old ones are blown it will help, but you'll still bottom out over bumps as they're made to work with the factory length/stiffness springs.
When I cut springs on my 780 I also swapped to bilstein hd's. The ride was more stiff but rode fine.
3 coils is a lot to cut. On my old 240 I cut 2 coils off the front and wouldn't do any more than that. If you don't have any money, just find uncut springs to put back in, or maybe cut one coil off until you have more money.
daijoubanai is offline   Reply With Quote
Old 10-31-2020, 11:53 PM   #13
LC4CARL
Aero challenged
LC4CARL's Avatar
IPD sport springs are an inexpensive compromise until you get your coil-over fund together.
@PDXvolvo on IG
Old 11-02-2020, 03:09 PM   #14
mikep
The MP
mikep's Avatar
If by "all messed up" you mean somewhat stiffer, yes. But stock volvo springs are less than half the rate they should have been in my opinion. Any plush 3000 lb car today has 150# springs. His problem is being almost on the bump stops on soft springs with no damping..
Originally Posted by leecatd8209 View Post
Being dead has a funny way of messing up your small business, too.
Old 11-02-2020, 07:08 PM   #15
klr142
Turbo, what?
klr142's Avatar
