Old 10-23-2020, 12:44 PM   #1
BeaverMeat
Default To cat or, not to cat
Wanting to install a high flow cat on my custom 5.0 swap exhaust. Anyone install cats in their 5.0 or LS swap and where is the optimum placement?
The car has headers that lead into a 2” Y-pipe into a 3” single all the way to the rear.
Is it best to use two spun cats on the 2” Y-pipe right behind the headers, or one cat on the 3” single after the y-pipes?
NOTE: I know all the rhetoric. “It adds weight” or “it reduces performance” yadda, yadda, yadda. It’s not 1985... for practical purposes I want my car to stink less...
Old 10-23-2020, 12:52 PM   #2
culberro
culberro's Avatar
I run 2x 2.5" cats on my 5.slow drift car. They are positioned to be just in front of the trans crossmember. I mounted them in this location to have increased ground clearance on a lowered car, and two 2.5" cats have more flow potential than a single 3". I mounted them with cheap v-bands. If they fail, I can easily swap them out or replace them with a straight section of tubing.
You could easily run a single 3" cat further back as well.
Old 10-23-2020, 12:53 PM   #3
Yes, running a cat is always a good idea on a street car.
Just to argue with Bobbert, a single 3" would be cheaper and simpler.
Old 10-23-2020, 01:39 PM   #4
BeaverMeat
Good to know. Wasn’t too sure if a modern 3-way cat could be placed right after the header. I know if it’s placed closer to the heat source it helps with efficiency but, you run the risk of burning it up.
Having a singe after the Y may be cheaper... bobbert does have a good point about flow potential with having two.
Well... if there is anything worth doing, it worth doing rightz
Old 10-23-2020, 03:59 PM   #5
740atl
educator monkey
740atl's Avatar
Less combustion stench with the cats.
They’ll be slower to get going but will still be functional. Make some heat shields around them.
Old 10-23-2020, 04:19 PM   #6
fatcatbestcat
Professional Hack
fatcatbestcat's Avatar
Meow.
Doing the wrong thing the right way.
Originally Posted by redblockpowered View Post
Will you do $14.99 shipped?
Originally Posted by IansPlatinum View Post
please no more prying things with screwdrivers and bashing things with hammers!
fatcatbestcat is offline   Reply With Quote
Old 10-23-2020, 04:27 PM   #7
This,
It's good to be considerate of everyone around you.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 10-23-2020, 05:46 PM   #8
Ursan
Bored Member
Ursan's Avatar
Run with a cat. Don't be that guy.
how psi a stock can support?
I admit I'm stupid...
Old 10-23-2020, 08:53 PM   #9
mikep
The MP
mikep's Avatar
area of 3" is 2.25x the area of 2". So I would go with the 3" since it should flow more, it's simple, and it will light off eventually. Not ideal for hybrids, but you will have it cooking for longer periods of time.
Originally Posted by leecatd8209 View Post
Being dead has a funny way of messing up your small business, too.
Old 10-23-2020, 09:32 PM   #10
2turbotoys
Astro Zombie
2turbotoys's Avatar
You could always use a free flow cat like this, and it's only $40 in stainless steel
http://www.siliconeintakes.com/dsm-i...ter-p-320.html
Properly tuned cars don't stink much more than factory cat cars
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
2turbotoys is online now   Reply With Quote
Old 10-23-2020, 11:04 PM   #11
BeaverMeat
Originally Posted by blkaplan View Post
This,
It never had a cat for the last 17 years and he drove it in the summer only. Never noticed the smell until it got colder outside.
That’s just a test pipe to “fool” da man.
The extent of tuning on this car is a OE 1989 5.0L with a 70mm throttle body, K&N filter, headers, and cat-less exhaust. That’s it. Crappy cams and all.
Stinks like any old 5.0L
Old 10-23-2020, 11:55 PM   #12
2turbotoys
Astro Zombie
2turbotoys's Avatar
I know what that is, was kind of a joke. Tune it then. Ever get behind an old carbureted car? That stinks. Most modern cars with a proper tune do not have that problem. You can not get a tune for that engine? If not, get a high flow cat.
Old 10-24-2020, 12:54 AM   #13
BeaverMeat
I comes down to cash.
Column A: get a cat
Column B: get an ECU
Cost to value... the cat wins.
Old 11-01-2020, 12:06 AM   #14
LC4CARL
Aero challenged
LC4CARL's Avatar
Here's a Magnaflow I had years ago. Super easy to place.
@PDXvolvo on IG
Old 11-02-2020, 12:30 PM   #15
Its not just smell. Your nose is not a full spectrum exhaust gas analyzer.
Yes its true,,, if your car is well-tuned you have less of a need for a cat but you are thinking mostly about steady-state cruising when the car is warm. Accel / decel + warmups are not clean.
You can pass a sniffer test with just a stead state load without a cat if the car is tuned well, but that same car on a dynamic dyno will quickly fail.
Old 11-02-2020, 12:41 PM   #16
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
they don't really kill power either as long as they're sized reasonably and not clogged full of ****
Megasquirt Tuning!
Old 11-02-2020, 01:31 PM   #17
dalek
Benchracer Tribe
dalek's Avatar
I do dig your hobbit cat. P/N?
Feedback!
Old 11-02-2020, 02:09 PM   #18
240wagonguy
I'm running no cats on my ls swapped C10 and there's no stinky combustion smell.
Old 11-02-2020, 03:06 PM   #19
mikep
The MP
mikep's Avatar
I'll have to disagree with the idea that you can tune away hydrocarbons. I can smell any vehicle with no cat. I worked for Datsun in the late 70s and early 80s, and we had cars with and without. The ones without a cat definitely got the hose when they were running in the shop. The CO is another story, of course, and now I know all cars need the hose.
Old 11-05-2020, 12:20 AM   #20
BeaverMeat
Went to a muffler shop and there telling me the only way to fit a cat is with a single unit on the 3" pipe. They suggested to go with a 2.5" inlet model... it would "work" but, I still maintain going with a small 3" inlet cat like yours.
I'll have to go back and show them the magnaflow mini-cats. I don't think I need the heat shield if its that small.
That's because it's an LS with it's fancy pants electronics and sensors, individual ignition coil packs, and more accurate "cold wire" MAF.
A 5.0 H.O. is just a classic 302 with mid-80s "hot wire" MAF electronic sequential fuel injection that controls the engine by fuel delivery only.
LS is a Playstation... the 5.0. is an Atari.
Old 11-05-2020, 02:11 AM   #21
Toybox
mostly lurking
Toybox's Avatar
I've always suspected as much... good to know what a tuner has seen firsthand, thanks!
I wish we were allowed to deviate dimensions, in California. It makes intuitive sense to reduce restriction by increasing pipe size, for example a 3" cat in the middle of a 2.5" system. With cone-shaped transitions, to ease the flow. But that type of free thinking ain't good for us, apparently.
