Old 10-25-2020, 04:03 PM   #1
Chooch84
Question OBD connector contacts
Hi,
I'm looking for help. I'm trying to find some OBD connecter contacts for a 1996 Volvo 940. I've browsed through over 500 contacts on Digi-key and rs-online trying to find something, the closest contacts I've found as JAE Electronics MX5-B-SG-C2-5000. Having ordered these, they're a loose fit but they lock-in and the male obd pin doesn't fit.
Does anyone know where I can find these connector contacts? Or are they obsolete?
Any help hunting these down would be appreciated.
Kind Regards,
Chooch
1997 945 LPT - TTV flywheel, 850R clutch, 3inch exhaust, 100 cell sports cat, AEM UEGO wideband, AEM EBC, 19t. DO88 intercooler & rad kit, VXR blue injectors, Front suspension polybushed, chipped,Bilstein B6's, cobra spings, Kaplhenke camber plates, adjustable control arms, Wasted spark, Kg2t, 531 head.
Ready to go on; Haltech 2500 Elite... Davies Craig water pump, LS2 Coils... various sensors....
Chooch84 is offline   Reply With Quote
Old 10-25-2020, 04:28 PM   #2
J-38125
Old 10-25-2020, 04:37 PM   #3
Chooch84
Thumbs up
J-38125
Thank you, do you know who the manufacturer is? Google, RS-Online, Mouser, Digi-Key, and farnell aren't bring back any results. I'm guessing they're obsolete?
Old 10-25-2020, 04:41 PM   #4
84B23F
84B23F's Avatar
A Volvo dealership's parts person should be able to find them....in paper based parts' books, connectors were listed.
Old 10-25-2020, 04:42 PM   #5
84B23F
84B23F's Avatar
He listed a kit part number, costing some $10k...a joke
Old 10-25-2020, 06:15 PM   #6
Post
Look closely at the connector.
Old 10-25-2020, 08:26 PM   #7
apachechef
Burnt Sierra Madre
Hi,
Chooch
another 940
Dammit, Lummert.
Old 10-25-2020, 08:34 PM   #8
84B23F
84B23F's Avatar
Will this work?
GM OBD 2 DLC Kit 1996-up All Makes Diagnostic Connector w/ Terminals Panel Mount
Old 10-25-2020, 08:38 PM   #9
TestPoint
TestPoint's Avatar
'96 ? ? ?
That was not the standard interface for OBD in 1996 . . . in the US for 1996.
Cut the connector off and install the then/now connector. Might need a wiring diagram.
Ford V8 Conversion Manual -
Old 10-25-2020, 08:38 PM   #10
84B23F
84B23F's Avatar
Look closely....
Now, pay attention: OBD-II was standardized, so one tester fits all...
Overview: The On-Board Diagnostic Connection System is designed to meet SAE J1962 specifications using ISO standard male terminals. The 16 Terminal Male Test Equipment Connector includes a nylon insulator with ISO standard copper alloy male terminals. The Female Vehicle Connector is designed for under dash application, and accepts 150 Series Metri-Pack tangless female terminals available in silicon bronze.connector.
Old 10-25-2020, 08:40 PM   #11
84B23F
84B23F's Avatar
Originally Posted by TestPoint View Post
'96 ? ? ?
"All 1996 and newer model year gasoline and alternate fuel passenger cars and trucks are required to have OBD II systems."
Old 10-26-2020, 04:15 AM   #12
Chooch84
Originally Posted by apachechef View Post
another 940
Thanks for the useful input.
Old 10-26-2020, 04:22 AM   #13
Chooch84
Originally Posted by 84B23F View Post
Will this work?
The contacts have the locking fin on the wrong side, I'll have a look to see if I can get another picture elsewhere, the image might be inverted.
Just to clarify, I'm UK based and we had 940's sold to us until 1998, so we did have OBD II ports, whether they worked with generic OBD II readers at that time is a different story.
Thank you for your help so far!
Old 10-26-2020, 07:33 AM   #14
84B23F
84B23F's Avatar
Just to clarify
OBD and OBD-II have specific meanings...
EOBD - The European on-board diagnostics (EOBD) regulations are the European equivalent of OBD-II, and apply to all passenger cars of category M1 (with no more than 8 passenger seats and a Gross Vehicle Weight rating of 2500 kg or less) first registered within EU member states since January 1, 2001 for petrol (gasoline) engined cars and since January 1, 2004 for diesel engined cars.[13]
So, goto a Volvo dealership in UK, and let the parts person find the right connector.
Old 10-26-2020, 07:38 AM   #15
Chooch84
I had some other "OBD" contacts which I didn't try before. After chopping off one of the locking tabs to make it look like the existing ones, I managed to get it to work. See https://uk.rs-online.com/web/p/crimp-contacts/7122056/ for part.
Thank you for the help.
Old 10-26-2020, 07:39 AM   #16
Chooch84
The connector states Volvo, the contact will not have anything stamped in it. Either way I've sorted it.
Kind Regards,
Chooch
Old 10-26-2020, 10:09 AM   #17
Fa182
Stage 1
Fa182's Avatar
After seeing your post, I was browsing the parts catalogue for 94-98 940's up and down but neither the OBD connector itself or the terminals are anywhere to be found in there, which is weird.
I even tried to look it up in the 850 parts catalogue because I thought they must be using the same connector, but same story.
Anyway, glad you found a solution.
Fa182 is online now   Reply With Quote
Old 10-26-2020, 12:31 PM   #18
84B23F
84B23F's Avatar
...connector...Volvo
Yours does not appear to be a version of Volvo's "OBD" found in US 1989-93 Volvos that I'm aware of.
I suspect yours is a OBD-II version....check out these connectors: 150 Series Metri-Pack tangless female terminals
Old 10-26-2020, 12:47 PM   #19
Kind Regards,
Chooch
What'd you do, Chooch?
Old 10-26-2020, 01:13 PM   #20
Chooch84
I ordered some of these a few weeks ago https://uk.farnell.com/amp-te-connec...2293342?st=obd
Never tried them before due to the offset of the hole for the pin, gave it a go after trimming one of the locating fins of as seen below.
It locked in place using the locking tab and the slide lock.
The pins in the OBD has enough give to make make contact and allow the connector to seat home.
Old 10-26-2020, 01:48 PM   #21
Ok. Glad you got it. We're they spread, or corroded?
I'd be interested to see a pic of the entire connector. Also, it sometimes takes a magnifying glass to identify the type of marking, but there may be some type of marking on the connector, Bosch, AMP, etc. I've been trained to find that marking and then look for the part number for the terminals in my J-38125 manual.
Old 10-26-2020, 02:06 PM   #22
Chooch84
I was looking to add CAN Hi & Low to pins 6 and 14, the Haltech Elite allows me to use a generic reader if I want to.
I've put the centre trim back together now, if I have the trim out at some point in the future I'll get a magnifying glass and take look.
Regards,
Chooch
Old 10-26-2020, 02:32 PM   #23
I see. Yeah, terminals 6 and 14 would need to be added for the high speed CAN bus. As far as what brand connector Volvo used there and which terminals you can stuff in there, I have no idea.
Thanks for posting back.
Old 10-26-2020, 04:22 PM   #24
Fa182
Stage 1
Fa182's Avatar
95-98 940 models use an OBD-II connector in the bottom of the armrest compartment and they removed the diagnostic unit in the engine bay.
I don't think any US -95 940's have that connector?
However the protocol is not OBD-II as it can't be read with the usual OBD-II readers.
As far as I've read, Volvo used a different (or pre) version of the protocol.
I've seen a guide to a DIY reader for these cars on the UK Volvo forums somewhere.
