Old 10-26-2020, 07:18 PM   #1
spock345
spock345's Avatar
Default 122s door sag
The doors on my 122s sag a bit. How difficult would it be to find new hinges to replace them? Which wears first in these, the hinge body or the pin? Should I just try to adjust the doors to deal with the sag?
1967 122s, B18-D, M40
2012 VW Tiguan 6 speed auto
Old 10-27-2020, 10:13 AM   #2
cwdodson88
Pull the pins, measure and hit McMaster
The Build Thread
SVEA - PUSHROD TURBO!
Old 10-27-2020, 11:56 AM   #3
planetman
planetman's Avatar
If needed, new hinges are still available.
Eric
Torrance, CA 90502
Old 10-27-2020, 12:48 PM   #4
spock345
spock345's Avatar
I guess I will figure it out when I get them apart.
Any tips on getting the phillips head screws out? I have had trouble with those on different cars in the past.
I wonder if anyone has tried reaming them out and installing bushings similar to what some American cars do.
Old 10-27-2020, 12:55 PM   #5
The Librarian
User an impact driver with the proper sized bit to remove the Phillips head screws.
This kit looks like it has the right bit.
https://www.amazon.com/Lisle-29200-H.../dp/B0002NYDRG
Old 10-27-2020, 02:06 PM   #6
tintintin
+1^
I've had best results when using it with a heavier hammer requiring less swing. Less tendency for the impact driver to bounce around, and less chance to deform the underlying sheet metal.
