Old 10-27-2020, 04:30 PM   #1
Avtovaz
Default low power output? b230a rally motor
I have a volvo b230A engine in my bmw compact. It has rebuilt bottom end, standard pistons etc. It has a 531 head, not modded apart from a skim, and a cometic head gasket, i think in all we took off 1.8mm. It has lh2.4, cast exhaust manifold [cant get any other in easily as its right hand drive car!], down pipes are 50mm then 63mm. The camshaft is a KL racing camshaft, its this one its 300 deg, 12.9mm lift.It has microsquirt ecu.
click here
thats the map done recently.
Now ive been told a few things, KL racing camshafts are useless, the cast manifold isnt restricting it, the lh2.4 isnt restricting it, the exhaust isnt restricting it.
So, what do i do? the cam is it too long duration for it to make good compression? is the cam just not good, or is there something im missing?
thanks
Avtovaz is offline   Reply With Quote
Old 10-27-2020, 05:09 PM   #2
esmth
I may be punching above my weight, but I believe the intake could be a restriction. Are you running the stock B230F / FB / FT intake?
1991 244 LH2.4 M46 352k miles
Old 10-27-2020, 05:16 PM   #3
What you are missing is that the stock head won't move enough air to make any more power than what the engine is making. 160 whp is about as good as you could ever hope for with that setup. Next up the intake manifold is not that great either. Once you get a cylinder head that flows more than 160 cfm and an intake manifold that isn't a choke point you will begin seeing improvement.
Old 10-27-2020, 05:22 PM   #4
Avtovaz
I think it is the stock inlet, , but ive been told itll do 200 bhp ok?
That is the flywheel power, so its much less at the wheels. I cant use anything but the standard inlet, its part of the rules of the rallying i do.
The rules are along the lines of has to be 4 cylinder, for 8v can be twin choke carb or injection that was fitted to that engine as standard. ECU is free,
I thought that the 531 was this awesome head that can do all sorts? Or is it not as good as i believe?
thankls for the replies, its really hard to get good info.
Old 10-28-2020, 03:23 AM   #5
SkeTchy-MechAniC
SkeTchy-MechAniC's Avatar
well.. I just bought the same cam and was hoping for 200 fly .. Guess it could be the wrong one
Never have i ever .... Seen a 242 with two motorcycles in the back
SkeTchy-MechAniC is offline   Reply With Quote
Old 10-28-2020, 12:37 PM   #6
culberro
culberro's Avatar
You need like 11:1-12:1 CR to take advantage of that cam, and you can probably get away with more.
The unmodified head is a huge bottle beck, especially on the exhaust port.
The stock intake manifold is a huge bottle neck as well.
Kyles (klr142) makes like 155whp (solid torque curve!) using a b21 k-jet manifold, a very modified head, 12:1 CR, and a much larger cam than the KLR T5. The issue is the intake manifold...
A modified head , 45mm DCOEs, and a similar cam spec has been shown (time and time again) to net close to 240 crank HP.
Old 10-28-2020, 12:50 PM   #7
culberro
culberro's Avatar
Have you read through these?
https://forums.turbobricks.com/showthread.php?t=354499
http://forums.turbobricks.com/showthread.php?t=221925
Old 10-28-2020, 01:01 PM   #8
90volvo
Maybe you can port the head and get or port you intake manifold. I worked with a guy that had a flow bench. He would tested intake manifolds for me. It wasnt Volvo but think the same principle applies. The intake will flow at percentage of head. I ended up with a 80 percent intake flow compared with the head intake flow. So if you can get the head to flow more and get a good intake I bet it will make a huge difference. Culberro did my head on my new motor, he knows what hes talking about and does outstanding work. I would be pm him if I was you. Good luck.
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
Old 10-28-2020, 04:24 PM   #9
Avtovaz
right ok, i thought the 531 was a really good flowing head over the 530. Everyone goes on about the 531 as if it makes the massive power as it is.
my friend had a boat motor 2.5, 531 head, skimmed it right up, v cam i think he said it was, on split 50 carbs, dizzy. It was doing 156 bhp at the wheels on his escort, so when i was looking to do my engine i was expecting more as it had the cam etc. He had the cast exhaust manifold too.
I havnt said this before but my inlet is modified, its 59mm, and slightly opened up, i cant do this but no one will know.
So what shall i do? Is there more power there easily gotten?
Old 10-28-2020, 04:27 PM   #10
culberro
culberro's Avatar
What are the rules for your racing series? Can you post a link to them?
Old 10-28-2020, 04:28 PM   #11
culberro
culberro's Avatar
The 531 has better intake ports, but the same crappy exhaust ports (that's where the major restriction is), and larger combustion chambers so the compression is lower.
A stock 531 CAN make more power than a stock 530, but a ported 531 and ported 530 are nearly identical.
Old 10-28-2020, 04:49 PM   #12
Avtovaz
click here
page 14 is that links right, basically its on the road at night, it says you have to keep a standard looking car, but can mod it apart from that in certain ways.
so;
18.2.Vehicle engines must have:
18.2.1.A maximum of four cylinders.
18.2.2.A maximum of two carburettor chokes (two single or one double).
18.2.3.A maximum of one camshaft per bank of cylinders.
18.2.4.Engines with more than one camshaft per bank of cylinders may be used providing that they were originally fittedwith fuel injection and that the fuel injection system complete with plenum chamber and throttle body is retained unmodified.
18.2.5.For diesel and petrol engines under 1500cc actual capacity, forced induction is permitted providing that thecomplete original induction system is retained unmodified,other than the replacement of the air filter element.
18.3.1.Fuel injection may be fitted where it was standard equipment by the manufacturer for that engine type and wherethe original plenum chamber and throttle body is retained for that engine type.
right ok the ports make sense then, adn im only at like 11:1 compression. maybe i should get another head and try again but use a 530 and go from there.
Old 10-28-2020, 04:59 PM   #13
Sounds like you should either go with a B234 head (if you want to keep EFI) or twin DCOEs
Old 10-28-2020, 05:02 PM   #14
Avtovaz
im in the uk, i dont think there is many of those heads here? Also, the 8v is in the car running, ts not bad as it is, just expected more and if there is more easily gotten, then ill have another go. The dcoe, you have to split them, and use only one choke, so itll cost like £1500! i could use 2 bike cars, but again, i now think its the head not the induction
Old 10-28-2020, 07:48 PM   #15
culberro
culberro's Avatar
It's a combo of the head and induction. Sad that you can only have 1x DCOE on the engine.
The stock intake manifold is good for ~180 crank hp, that's it. The rules state you must have the same throttle body and plenum, can you replace the runners in the intake manifold with larger tubes? Can you replace the b230 intake with a k-jet intake? Can you port the intake?
The head you have is fine, it just needs the exhaust worked over, the exhaust side of the chamber unshrouded, and the head milled for 12:1+ CR.
Old 10-29-2020, 12:53 AM   #16
fastcomet
If you don’t want to pull the head. Get a smaller cam with more duration on exhaust side. If your stock compression then your cam is way to big.
fastcomet is offline   Reply With Quote
Old 10-29-2020, 09:41 AM   #17
Jussi Alanko
With stock intake manifold and a 531 head with 46/38 valves, unported makes 210hv with timos 13.10 camshaft and a original intake manifold.
Same combination with non-ported 530 head makes 200hv.
If heads were ported numbers will be something about 240/230hv.
530 head ->
https://www.youtube.com/watch?v=IJUfQ1a5-JM
531 head ->
https://www.youtube.com/watch?v=vgpnXDQLefU
Jussi Alanko is offline   Reply With Quote
Old 10-29-2020, 10:55 AM   #18
SkeTchy-MechAniC
Stock LH?
Old 10-29-2020, 02:24 PM   #19
Dirty Rick
Dirty Rick's Avatar
A 300° cam is not a good thing on a relatively stock motor. It is going to need a healthy boost in compression to work at all, but then the RPM range it works at is way above normal street use.
Old 10-29-2020, 03:01 PM   #20
Sjeng
Sjeng's Avatar
530 head ->
531 head ->
Impressive. Compression ratio must be key here, any figures?
Old 10-29-2020, 03:52 PM   #21
Avtovaz
i had asked Timos ages ago for the price of a camshaft, and it hink he gave it me but when i asked to order it he never replied, and i mailed a few times.
But he said they run at least 12,2mm lift 286 dur, in the 213hk engines lift is about 13mm and over 300 dur.
so what should i do to my engine then? if i have a go at the exhaust ports, and skim the head so i get 12:1 static? will that make 180 bhp with the cast manifold? I could make my own exhaust manifold but id rather loose 5bhp than spend the time making one as this engine is in a RHD bmw compact.
I do actually own the bigger valves that fit in the head, i forget their sizes, maybe i could get a 530 head and port that and put these valves into it. keep the 531 as it is.
i dont know what to do but i had a m44 bmw engine in the car before, it made 180 bhp and 160 lbs, now i was told the 2.3 would be a lot more torque and 190 bhp by everyone i talked to, but so far its far from that.
thanks!
Old 10-29-2020, 10:30 PM   #22
90volvo
fix up a 530 head and sell the 531 when your ready to do the swap. Step down on cam a little. Get a good intake and ex. manifold. At least thats what I would do.
Old 10-30-2020, 08:06 AM   #23
Jussi Alanko
You need to extrude hone the intake manifold, or use a k-jet manifold and extrude hone it, it flows a little better and have a bigger plenum.
Your compression must be between 12:1 to 13:1.
HEad is moast important thing, you need to change valves to 46/38, then port the 530 head. (my ported 530 with 46/38 had flow rates to make 220hp).
Then you need good headers to it.
Your camshaft is good enough.
If needed more power port the 531 with bigger valves and install a cam that has max lift about 14.5mm and duration at 0.050" something about 280 degrees.
Old 10-30-2020, 12:26 PM   #24
culberro
culberro's Avatar
Jussi, the power figures you mentioned above with the Timo’s cam, was that with an extrude honed or ported intake?
I ask because the ID and CSA of a b230f intake runner is VERY small, especially at the fuel injector area.
I fully agree on the compression numbers. People are afraid of high compression for some reason. I don’t understand.
Old 10-30-2020, 01:33 PM   #25
Jussi Alanko
Intake was original.
But it is biggest restriction with those engines.
Extrude honing or porting makes at least 10 extra hp.
