Old 11-12-2012, 12:53 AM   #26
AndrewNance
Amateur hour!
AndrewNance's Avatar
If it causes a problem I'll switch. Until then it's there and working.
'71 142
'80 245
Feedback
Old 11-12-2012, 04:37 AM   #27
iwannadrive
Originally Posted by pstevens3307 View Post
All the time you're spending figuring out what to do about mounting the thing - fuggeddaboudit. Buy the SW-EM kit. Yeah, it's a hundred bucks. It's also rugged as hell, works great, it's easy to install, and Ron's instructions are excellent. Use the time and imagination you were going to devote to this on something for which there isn't such a no-brainer solution.
BTW, the 10/12SI alternators are *not* one-wire, they're three-wire. Marginally more complex to set up, but they work better. And you get to keep your red amp light in the dash. Most people find that it's worthwhile. And like I say, Ron's instructions are excellent, so you should have no problems.
One thing I'll suggest as an addendum/modification of Ron's approach. Ron's kit is set up to connect the voltage sensing wire (the third wire of the three, the one that doesn't connect to the amp light or the battery) to the battery output stud on the alternator. While this will work, it means the alternator is measuring the voltage at the "best case" point. It's better to connect the wire to the power distribution stud (which should be mounted on the firewall). That way it'll give you a more accurate reading of actual voltage in the system.
you're probably right. I just really like to build stuff myself. I like trying to engineer ways to make things work, it's kinda just the way that I am.
when spring comes, I'll probably pick up a 10/12si alternator, look at it, realize it will take a bunch of work to make fit, and then pick up an SW-EM kit.
do you guys think that putting a new set of brushes in my generator is worthwhile? the previous owner of my car stated that it was recently "professionally rebuilt", but it was working kind of erratically until it quit charging, came back to life for a small period of time, and then quit again. It would be pretty cool to keep the originality of the generator if possible. I already tested the voltage regulator by quickly bypassing it, and that doesn't seem to be the issue.
iwannadrive is offline   Reply With Quote
Old 11-12-2012, 04:46 AM   #28
ibcmoore
ibcmoore's Avatar
I think I'd go with an alternator rather than mess with brushes on that old generator. My wife's B20-equipped 220 has an alt and it's WAAAYYY better than the gen on my B18-equipped 122 sedan. I'm waiting for that gen to fail me and then I'll swap to an alt.
cmoore
WANTED: Volvo C306 (1314) 6x6 with radio/ambulance box
Posted by TrickMick on 122313: "ether be yo fren".
ibcmoore is offline   Reply With Quote
Old 01-29-2015, 03:17 AM   #29
Brenie84turbo
Amazon newb here wondering if I can use this alt that Ron says to use with his kit on my Amazon I have a b20 swap and I have the front mounting hole I'm trying
To avoid the ext voltage reg I got my self a Bosch alt for a 140 with b20 thinking
It would be internal but it's not and I rather not have to track down one if I could use the alt that Ron says to get for his kit would it bolt up to the hole that's on the b20's stock and only require how to wire in the three wire bypassing and removing the original voltage reg for the gen? If so can anyone send me that info for wiring it up with the 10 or 12s?
Brenie84turbo is offline   Reply With Quote
Old 01-29-2015, 03:39 AM   #30
745 TurboGreasel
745 TurboGreasel's Avatar
I used one on a B20 Amazon, but made my bracket out of an old Chevy one I think, so can't say if the kit works.
Local part store has a new alt connector, use it if you don't get a good bit of harness at the junkyard.
I do them like this;
Put a ring terminal on the red wire, run that to the batt post on the alternator
A hearty wire, best with a fuse link to the battery to the alt batt post
the other wire from the plug joins the one coming from the charge light to the old regulator.
Works on most cars.
Feedback
Old 01-29-2015, 04:11 AM   #31
Brenie84turbo
So there is no need to wire anything back to the large black wire that comes stock in the harness that went to the back side of the voltage reg b+ and thenother red wire I'm guessing next to it went to the dash light
Old 01-29-2015, 04:12 AM   #32
Brenie84turbo
Thanks for your help I'm going to read some more
