Old 01-03-2016, 08:27 PM   #1
TIPSP
Got Boost?
TIPSP's Avatar
Default The 75 242 DL
Images should be updated soon... for the time being, you can view the story here: https://www.projectmoro.com/1975-242[/B]
More images are here: https://imgur.com/a/ucHSz
I bought a supposedly running car from a forum member to replace my totaled 82 244turbo.
1975 242 DL with a B20, k-jet, auto, and only 49,800 original miles supposedly.
Here is the car when I got it.
Nothing worked on the car. Mold in the carpets. Rear calipers frozen, Distributor drive gear broke, Fiber gear was missing teeth. Engine was gross. Carbon build up and slugged oil. Gas tank rusted. Injector and feed lines ruined.
Rust on the headliner. Cleaned up some of it.
The interior was leaking water, hence the rust and mold. Fixed that problem.
Some quick paint in the bay.
Fresh carpet.
Added Better looking mirrors
Brand new GT (R-sport) gauge cluster to go in very soon.
Transferred the parts from another car, and my old totaled 244turbo.
Finishing rust removal and the under coating.
New seals:
Yoshifab x member. Modified.
TIPSP is offline   Reply With Quote
Old 01-03-2016, 08:28 PM   #2
TIPSP
Got Boost?
TIPSP's Avatar
Custom Drive shaft
Finished cleaning the rear end
Lower mounts for the engine.
Was going to mill them, but somethings happened and the machinist was busy.
New exhaust
Learning to tig on this car.
Old 01-03-2016, 08:28 PM   #3
TIPSP
Got Boost?
TIPSP's Avatar
RSI adapters didn't fit right
New Master
New Fuel Lines everywhere
Stereo Modeling
Fuel filler neck adapter I made
Stereo Continued..
Old 01-03-2016, 08:43 PM   #4
TIPSP
Got Boost?
TIPSP's Avatar
Stereo Cont...
Cleaned up some of the wiring
New Rims:
Added a resonator to keep it more street friendly.
Teaser:
Alignment. Left over 80-20 works great.
First Trip to the station.
It took way to long to get it running, but it is running now.
Some wiring is left, and the supercharger and rear brakes. Then it will be done.
2.5 years of waiting to drive it. It is fun to drive.
Old 01-03-2016, 08:51 PM   #5
Chance
1 throttle plate per cyl!
Chance's Avatar
Looks amazing. Nice work
DD's
2010 Jeep Patriot
2015 Dodge Journey
Currently restoring:
'66 122s 2dr - B20 dual webers/M41
Projects:
'83 245 - SBC 388 stroker with Jenvey 45 ITB's
Chance is offline   Reply With Quote
Old 01-03-2016, 09:00 PM   #6
sksmith
sksmith's Avatar
What was leaking causing the molding carpet?
Old 01-03-2016, 09:04 PM   #7
TIPSP
Got Boost?
TIPSP's Avatar
Here is when it was first started after 2.3 years.
Without resonator. and first rebuilt fuel distributor I did. We Rebuilt Kjet distributor once, and cleaned out the injectors (thanks Ian). Also opened and cleaned the CPR. I bought a new rebuilt distributor because I had to open the other one back up again. Didn't have a new plate for it. Ran like crap the second time I took it apart.
I will have to get more videos later.
Old 01-03-2016, 09:06 PM   #8
TIPSP
Got Boost?
TIPSP's Avatar
The seams on the firewall. The caulking was missing. we re caulked the interior. Also the panels that bolt to the firewall. Re sealed all that.
Thanks,
Old 01-03-2016, 09:16 PM   #9
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
very well done. Great work on everything.
Old 01-03-2016, 09:31 PM   #10
TIPSP
Got Boost?
TIPSP's Avatar
Thanks,
And thanks to all the people that helped me get it done. Me and my dad did most of the work.
somethings like machining and the drive shaft where out sourced. I learned(ing) to tig weld on this car.
Ian (hiperfauto) played a major rolled with awesome parts and advice.
Ben helped with custom awesome parts, and some other people not on this forum help source parts.
oh, and this is my daily drive so it will not see too much boost.
The pulley is designed to run the charger at 14,000 rpms (which is like 10 psi), but I can control that with the bypass valve on the charger.
probably 5-7psi. should be like 160 crank hp.
Old 01-03-2016, 09:55 PM   #11
The Full Banana
not yet good enough
The Full Banana's Avatar
Wow, this is a really neat car. Very well done, I can't wait to see more!
-Tom 1980 242 T5
Old 01-03-2016, 10:04 PM   #12
That looks amazing. I had no idea you put so much work into this car. I'm glad you finally got it all sorted out.
And what's this about a supercharger? You never said anything about it.
Old 01-03-2016, 10:38 PM   #13
GTJordan
Been here for too long
GTJordan's Avatar
Beautiful work. Beautiful.
Old 01-03-2016, 10:42 PM   #14
DavoS40
DavoS40's Avatar
Awesome work, car looks great!
1983 245DL, 2011 WRX, 1978 SR500
DavoS40 is offline   Reply With Quote
Old 01-03-2016, 11:35 PM   #15
Nick Oc
This car is hands down the sexiest 240 I have ever seen. That interior is the sex.
Nick Oc is offline   Reply With Quote
Old 01-03-2016, 11:51 PM   #16
NO_SPRK
ihazkoolaid
NO_SPRK's Avatar
A+
Thanks for keeping the b20 in there!
69' 145 / 73' 142 / 84' 244
Buyer/Seller Feedback
NO_SPRK is offline   Reply With Quote
Old 01-03-2016, 11:52 PM   #17
Lord_Athlon
Just damn
Nothing I could possibly say holds a candle to the craftsman ship put forth; This car is stunning beyond all comprehension.
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
Old 01-04-2016, 01:03 AM   #18
brendon_ak
Oh. My. Lord.
Truly impressive, I'm gonna post some of these pics in the inspiration thread, you've more than earned it.
What made you want to stick with the b20?
Old 01-04-2016, 01:23 AM   #19
amerbritcan
Hnnnnnng
amerbritcan's Avatar
I love that interior. So awesome.
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 01-04-2016, 01:53 AM   #20
volvoshredder
volvoshredder's Avatar
Fantastic! So stoked to see someone revive a '75 and keep the b20.
volvoshredder is offline   Reply With Quote
Old 01-04-2016, 02:09 AM   #21
Jack
Banned
Jack's Avatar
really good job there.
what did you do to the undercarriage .... or I should say... how did you do it ?
Old 01-04-2016, 03:57 AM   #22
TIPSP
Got Boost?
TIPSP's Avatar
Thank you guys. Means a lot. Most of the cars on here are my inspiration.
lol, I didn't want to say anything about it till I figured out what I was doing.
But it is fun to throw in a teaser image here and there.
Originally Posted by brendon_ak View Post
Oh. My. Lord.
The car was suppose to be a quick put together and drive it as it was, we had parts ordered to fix the B20, so that is why it stayed.
It took a month of trouble shooting to figure out why it would not start. We were tempted to rip it out and stick a V8 to match the transmission in the car now.
I like the idea of the original engine in it also... Plus, not many people have a 75 242 with an Eaton supercharged B20 ;)
I haven't seen one yet...
The underside of the car was in pretty good shape for the most part. There was mostly surface rust. I used a wire brush on some parts, but most was taken care of by that rust removal/primer chemical (jasco). seemed to work okay. I believe it was SEM brand Rubberized undercoating.
Edit:
I used goof off, and acetone to the underside after the clean up so the undercoating had a better stick. Then I did a very light coat of summit racing black spray paint over the undercoating.
The axle was a more wire brushing. a lot more rust on that part.
Old 01-04-2016, 04:28 AM   #23
122power
dude
122power's Avatar
Wow nice work and car dude. First 75' 242 Ive seen in that color.
Old 01-04-2016, 04:34 AM   #24
Pro Sneaker Peddler
Suddenly one of my favorites. Good going, man.
Old 01-04-2016, 04:35 AM   #25
petiww
petiww's Avatar
Oh finally!
I liked this car from the beginning, even from the progress pictures of the 244 turbo you could tell this 242 is in good hands.
Although I was a bit curious about the titan rimpz on it at first. Fortunately you did not disappoint me!
Tasty, classic looking with a perfect ride height and a pushrod engine.
Hats off for you and your father, really nice work!
I hope this one won't get messed up by some idiot driver...
1980 Brown 244 GL
