Please post the info on how you installed them in this thread!
Well
Sundown Audio Makes some really nice stuff. Very function over form mentality when it comes to their products.
The driver they sell that i selected is their SA2.75FR i purchased from
here.
2.75" Full Range Speaker
4-Ohm Impedance
20W RMS Power Handling (Almost all of sundown audios stuff is underrated. With crossovers set correctly i can see this driver handling double.)
Frequency Range 170Hz - 20KHz ( i was told by one of their builders they are using a 200hz inline bass blocker filter)
Sensitivity: 88dB
Mounting Depth: 33mm
Its going to be hard to describe but i think you will get the idea.
I removed the factory tweeter and cut off the lower part of the plastic basket area using a small hobby saw.
once that is removed all you have to do is come in from the back side with a thin saw blade and make a slit that will be right above the mounting surface. Then you can push the tab of the speaker through this slit. The other side of the speaker tab the side with the little squares cut out just gets bent in a way that hold the speaker in place. The top of the tab gets bent over the edge of the plastic and the speaker grill holds it down.
In this picture if you look at the one that is completed on the left. Where the white sticker is you can see the tab on the speaker protruding through the slot i made. If you cut the slot too large and the speaker can be pushed too far through this hole you will not have as tight of a fit so remove material carefully untill you can get this thing to snap in just right.
Once you have your slot made you need to bend the other side of the speaker tab like shown below. The pink lines you bend those tabs out and the points on those tabs help hold the speaker in because they dig into the plastic slightly. The fold over the top needs to be done once the speaker is completely seated so that when you put the grill on over the top it will hold the speaker down where you want it.
You can kind of make out where that tab is under the grill in this picture.
Hope that makes sense...
