SteveMD
Membro
- Feb 15, 2004
- Well, I switched baristas.
Would a flat-surfaced lh2.4 dog dish flywheel work with a M90 set-up on a redblock? See this thread http://forums.turbobricks.com/showthread.php?t=177742
They're just taking chunks out of the sides...? Sure, that'll work. A flat flywheel with LH2.4 timing marks and a suitable clutch would work too.
cheers
James
How does that hook up anyway.. mine still doesnt work (we also redid the wiring but no worky)
you dont happend to have a pic of that
my brother and i will be doing an M90 swap on his 780. My brother did get the front section of the driveshaft from the M90-car but not the rear section. He has the IRS suspention on his 780-IRS.
Now here are my questions:
- does anybody know for a fact if the IRS drive shaft rear section will actually slide in the M90 drivehaft front section? (number of splines the same?)
- does anybody know if these 2-section driveshafts are balanced together (as an assembly) or is each section balanced solo?
