Old 08-04-2018, 07:59 PM   #1
logboy
Default 1981 242 fuse blow
Fuse 13 keeps blowing in my 81 242. It blows when the key is turned all the way. Also my turn signals don't work, not sure if that's related. Anyone have any ideas?
logboy is offline   Reply With Quote
Old 08-04-2018, 08:51 PM   #2
dbarton
Dejected by Volvo
dbarton's Avatar
That would explain why turn signals are not working. Not a lot of things on fuse 13. Start looking at some YouTube vids on tracing a short and start with your turn signals. Others may have suggestions.
Dave B
'84 242ti, owned since 2003. Always garaged since brand new. Old-school rounds because. B21FT, iPd Springs/Sways, SDS EFI/IGN, TD04HL-15G, T5Z trans with 0.73 OD retrofitted, 3.91 diff with G80.
Volvo seeks Divorce from Volvo Enthusiast Community: www.prancingmoose.com/#novolvo
Dave's Volvo Page: www.davebarton.com
Old 08-04-2018, 08:55 PM   #3
Seatbelt reminder wire is loose and grounded in the center console?
Old 08-04-2018, 10:26 PM   #4
logboy
Dave B
The weird thing is the still wont work with the fuse in. The hazards still work though.
I will take a look
Old 08-04-2018, 10:44 PM   #5
nel621
Or one or more turn signal wires worn through where they go through headlight backing plate area.
Old 08-05-2018, 01:13 PM   #6
dbarton
Dejected by Volvo
dbarton's Avatar
Hazards are on Fuse 9.
Old 08-05-2018, 02:16 PM   #7
logboy
fuse 13: Instruments, Turn signals, Relay fuel injection, Seat belt warning
http://www.autogenius.info/volvo-dl-...e-box-diagram/
I think it might be something with the fuel injection system. what is a common fail point? I have tried unplugging the in-tank pump, main fuel pump, fuel injection relay. still no luck.
Although, my seat belt warning light doesn't light up. When is that supposed to come on? After I have already turned the key? Fuse pops at position II of turning the key.
Old 08-05-2018, 03:06 PM   #8
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Seat belt warning is on fuse 4. The label Dave posted is for 1985-86 cars, so it's not very accurate for the older cars.
Has the wiring harness on the engine been taken care of? If not, you may have a short circuit in that, causing the fuse to blow. Another possibility is a short in the instrument cluster's circuit board. Pretty much check any blue with red stripe wires for damage or shorts.
Old 08-05-2018, 03:47 PM   #9
Unplug all the wires on the right side of the fuse and reconnect them one at a time to determine which circuit has the short. Then figure out what isn't working.
A wiring diagram might help you trace down which circuit is blowing the fuse. Here's a link to the '81 greenbook.
https://ozvolvo.org/archive/?downloa...AzMTYtMS5wZGY=
Old 08-05-2018, 10:45 PM   #10
logboy
I don't think so. The previous owner said he was having trouble with it. Its also covered in engine oil in the engine bay, so that probably doesn't help anything
I tried that, thank you. My dash lights and blinkers now work. Now to see what was on that other circuit. It must be the fuel system because I still cant start my car. Well, the seat belt warning hasn't lit up yet either, though.
Old 08-07-2018, 08:05 PM   #11
logboy
Ok I fixed the problem. Somebody had spliced before the fuel pump relay and the other end was grounded. No more fuse pop but still not starting lol
Old 08-09-2018, 08:47 PM   #12
300+hp on the shelf club
Thanks for letting us know you got it figured out.
