Old 08-09-2018, 03:32 AM   #26
Jack
junkman
Jack's Avatar
I tip my hat to you fellas. After doing h3/h4 and having the same plastic covers, I still just squint my eyes looking for road lines, hopefully freshly painted so that I can point and pray my 245
even a few years ago if I truned high beams on I would get flashed (not boobies ) all the time. These days nothing... eyes dont get use to the dark and older car lights (even upgraded) appear dim.... get off my topless lawn
I need to upgrade my wiring. Thanks for doing the hard work
Old 08-09-2018, 01:53 PM   #27
gottarollwithit
Cooks with motor oil
There are many mods to be had, but by far the best is a set of E codes AND a headlight relay harness. If you can afford to toss a couple hundred bucks at it, call Ray at Susquehanna Motorsports http://www.rallylights.com/
They can make you a custom headlight relay wire harness and walk you through installing it. They are the real deal and worth the $$. They use good quality connectors, wiring, heat shrink, etc.
1988 740 turbo wagon/squishmobile!
gottarollwithit is offline   Reply With Quote
Old 08-09-2018, 02:13 PM   #28
300+hp on the shelf club
I have also bought from rallylights dot com and they have been good to buy from. I bought a summit racing harness which was in the middle price wise. It was about $45 with shipping. Gary suggested it and I am very happy with. I put that on the 93 wagon. When I buy the individual parts like the excellent hella headlight connectors. I got them from rally lights.
As John mentioned above the 100 amp denso alternator is a nice update as well. I run a denso on both of my signature cars. 100 for the wagon and 80 for the turbo. Some 80 amp versions have the smaller B+ to match up to the older 240 wiring harness.
Old 08-09-2018, 06:56 PM   #29
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
It's also easy to modify the smaller ring terminal to fit the larger stud. Take a M8 bolt and run it through at an angle, bending the terminal slightly. Then, take a pair of needlenose pliers and squeeze the metal enough so it slides onto the bolt perfectly. When you install the ring terminal onto the alternator, it'll slide on easily and still make contact all the way around. The Denso alternators also have a smaller case than the equivalent old school Bosch alternators. The 80 amp is slightly bigger than a 55 and the 100 is about the same size as an 80 amp Bosch.
-J
Old 08-09-2018, 09:39 PM   #30
TestPoint
TestPoint's Avatar
Its late and dark and to avoid walking a hundred yards my question is 'should the low beams and high beams have different focus properties in the front glass?'
I checked the high beam/low beam H4651/H4656 front lens. They are very different. That leads me to believe that the available conversion lens that are all the same are a real compromise. The conversion lens appear to be similar to the low beam H4656 which would mean that the high beam would be disbursed all over rather than focused forward and down.
Any other options out there?
Ford V8 Conversion Manual -
Old 08-10-2018, 05:14 AM   #31
John242Ti
John242Ti's Avatar
^Buy only two H4 conversion lenses, and two H1 conversion lenses. Problem solved. Avoid the H4 conversion lenses with the "SAE M" mark on them. Those are meant for a motorcycle and, therefore, have the cutoff line that goes up to the left in addition to the right. Lots of light, but, not unlike a pair of DOT 1986-93 lamps, they kinda spread it everywhere. The ones that don't have that mark on them have a flat cutoff to the left, then it goes diagonally upward to the right, to light up street signs.
-J
