Old 04-13-2017, 11:34 AM   #1
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
Default 1994 940 cruise control issues
1994 940 cruise control. I can see the vacuum motor, it's got a hose running to the actuator, but there seems to be a nipple that has nothing on it but two hoses that come from the back of the pump. Are those outlet?
Issue is the cruise works only at highway speeds and only just. I'm not sure if the pump is working, barely working or if there's a leak.
I'm going to check all the connections and the switch on the brake and see if that needs another o-ring again.
Anything else I can try? Is there a way I can test the pump? How many inches should it be pulling?
how psi a stock can support?
I think this might be my chariot if I can jew the price down.
Old 04-16-2017, 01:38 AM   #2
Ursan
Ursan's Avatar
anyone?
Old 04-16-2017, 02:13 AM   #3
stiligFox
Part-time Tinkerer
stiligFox's Avatar
Can't shed much light but vacuum hoses would be first place to look, especially the elbows. I need to replace the elbow on mine because the inside bend has dry rotted badly. It doesn't look like it but when you flex it, there may be holes going clean through it.
stiligFox is offline   Reply With Quote
Old 04-16-2017, 02:35 AM   #4
Shifted
On the Hill
Shifted's Avatar
Also isolate the pull bellows and make sure it holds vacuum.
Codes/etc.?
https://www.volvoclub.org.uk/faq/CruiseControl.html
He built my Bose 901s all by himself...
Doing something because you enjoy it is a must in life.
Originally Posted by ME II View Post
Without mistakes there is no learning.
"The mountain streams that rush on by/Show the fish a-jumpin' and reflect the open sky/The fresh clean smell of the pines/Symbol of unchanging times/All around this sacred land/Strangely, though, I've found my way/Right here I'm a-gonna stay/In this land" Tom Johnston/Doobie Brothers "Ukiah"
Lifeboat for the plankwalkers/otherwise disenfranchised.
Shifted is offline   Reply With Quote
Old 04-16-2017, 10:27 AM   #5
There is a vent nip with nothing on it, I think.
Full shakedown of cruise would be learning how to read the various electrical signals using a high end multimeter or a scope. I was hoping to try this on my inoperable 86 740 cruise, but haven't yet.
Old 04-17-2017, 02:27 PM   #6
Ursan
Ursan's Avatar
I did check those last year. But I'll check again.
Old 04-17-2017, 02:33 PM   #7
2manyturbos
Like everyone above said, vacuum leak. It is most likely at the brake pedal switch/valve. That port on the pump is supposed to be open, no line attached.
Old 04-17-2017, 03:51 PM   #8
Ursan
Ursan's Avatar
I just checked the brake switch and replaced the o-ring there.
Old 07-13-2017, 06:29 PM   #9
Ursan
Ursan's Avatar
Okay, so the bellows doesn't hold vacuum. Where can one get a replacement?
Old 08-05-2018, 02:09 PM   #10
PST615
If there is a small pinhole in it, try a bicycle tire repair pad. Cheapest way to fix a leak on that one.
PST615 is offline   Reply With Quote
Old 08-07-2018, 02:50 PM   #11
tintintin
JY?
Old 08-07-2018, 03:01 PM   #12
https://www.tascaparts.com/oem-parts...m-unit-1273227
Old 08-07-2018, 03:12 PM   #13
2manyturbos
^^ Ouch. At least they still offer the part. I'll part with a used one for much less.
