waynegarbo
- Jul 18, 2018
- Fresno
Ok thanks I'll check it out.
Ok EVO I took the air box out. Yeah my thermostat sits in a molded cylinder in the air box. Yes, when you push on the thermo it opens the flap. The thermo spring cylinders a probe attached to the flap. That spring, I'm not able to remove, hence, remove the thermo.
So I shimmed a piece of rubber hose between the pivot and the housing in the open position and spread some glue over the top of it to keep it propped open.
