Old 08-02-2018, 05:02 PM   #1
Patestrickland
Patestrickland's Avatar
Question Sloppy steering
My 93 240 has a problem where if your going 60-70 the steering starts to feel really loose and sloppy but going around 45 it feels nice and tight. I’ve jacked the car up and checked for bad inner tie rods but the wheels are stiff. Could this be bad ball joints?
Patestrickland is offline   Reply With Quote
Old 08-02-2018, 06:51 PM   #2
TestPoint
TestPoint's Avatar
It could be any of the steering/suspension components or a combination of a little sloppy in several. At 25 years old it probably would a refresh of most of the components.
I had a rear bushing of the control arm fail that took a bit to diagnose.
Ford V8 Conversion Manual -
Old 08-05-2018, 08:21 AM   #3
Eleven
Eleven's Avatar
My guess is frontend lift
'76 245DL 240k miles
‘77 242DL 89k miles
'90 240DL 360k miles
Eleven is offline   Reply With Quote
Old 08-08-2018, 02:01 PM   #4
Jake_NZ
Jake_NZ's Avatar
Check to make sure the steering rack is still firmly bolted in - the u-bolts seem to get loose.
'80 Volvo 242 GT / '83 Volvo 244 GLT / '87 Volvo 760 / '88 Volvo 245 Propcar / '89 Volvo 245 Propcar / '89 Volvo 245 GLT / '95 Volvo T5R / '04 Volvo S40 2.4i
Jake_NZ is offline   Reply With Quote
Old 08-08-2018, 04:22 PM   #5
EivlEvo
Pate also check the steering knuckle. On my 87 something went bad with it right as I picked it up and each time I would turn, a few more needle bearings would fall out. It was pretty sketch.
Luckily a lot of the suspension stuff on these cars is pretty simple to tackle outside of a bit of muscle and the odd creative tool required.
Old 08-09-2018, 05:29 AM   #6
Otto Mattik
Otto Mattik's Avatar
Have helper turn wheel back and forth and look for slop on lower steering coupler ?
Originally posted by Jack
_________________________
