Old 08-02-2018, 10:35 PM   #1
mj4276
mj4276's Avatar
Question Help. Mystery part fell from volvo
Hi, I was replacing the injector seals on my 244 the other day and I heard something fall through the engine to the ground while I was moving the fuel rail. Underneath, all I could find was this brass ring:
Does anybody have any clue what this is? I put everything back together with no apparent missing pieces, and the car drives perfectly fine. Maybe it was just sitting there on the engine and unrelated?
mj4276 is offline   Reply With Quote
Old 08-02-2018, 10:37 PM   #2
Mbeas96
Mbeas96's Avatar
mmm, no pic for me, but are your grounds on the rail still there? under the bolts that hold the rail to the intake manifold
edit, nvm. I see you say runs fine.
Old 08-03-2018, 12:58 AM   #3
sbabbs
sbabbs's Avatar
The turbo hard lines use a brass ring for a gasket is all I can think of.
Old 08-03-2018, 06:51 AM   #4
A tough rowing ho
Fuel filter also uses those same kind of seals, if it's under the hood, someone probably dropped it while changing the filter.
Old 08-08-2018, 02:53 AM   #5
mj4276
mj4276's Avatar
Whoops sorry, I had email alerts off. The grounds are all there, my car is an NA, and the fuel filter is the kind that lives near the rear axle. I guess it was probably just sitting there when I knocked it.
