Old 08-05-2018, 12:13 PM   #1
LeedomtoFreedom
LeedomtoFreedom's Avatar
Default Sunroof repair
So the manual gearbox for my 264 sunroof is starting to bind. It'll spin fine and then the teeth will start to misalign and cause it to bind up. Has anyone found a solution for this or should I just buy a replacement.
Also still trying to buy a 016 or 012 AMM.
81 264 - Driveway ornament
90 245 - becoming 16v
Old 08-05-2018, 03:54 PM   #2
2manyturbos
The casting that holds the drive gear may be loose from the rest of the sunroof mechanism. That is what usually leads to the gear skipping.
Old 08-05-2018, 04:47 PM   #3
LeedomtoFreedom
I doubt there's a fix for this... Correct ?
Old 08-05-2018, 05:14 PM   #4
2manyturbos
There are two screws that attach that casting to two other castings that are part of the sunroof assembly. Take the handle off and see if the screws that hold that casting are loose. It may be that simple. If they are loose and tightening them makes everything work properly, remove them one at a time and put a drop of blue thread locker on them and reinstall them. They tend to work loose.
Old 08-09-2018, 10:29 AM   #5
LeedomtoFreedom
Yeah I suspected that, but after removing the gearbox and operating it separately it will just bind up at random intervals where the teeth meet head on. I'll probably just buy a new one.
Old 08-11-2018, 12:04 AM   #6
Jake_NZ
Jake_NZ's Avatar
The gearbox is supposed to bind up - it works on an eccentric to act as a stop to prevent overwinding.
It wont work unless you have pressure on it though, so refitting seems to be trail and error, well, that's how I've done it (don't let women wind them...)
'80 Volvo 242 GT / '83 Volvo 244 GLT / '87 Volvo 760 / '88 Volvo 245 Propcar / '89 Volvo 245 Propcar / '89 Volvo 245 GLT / '95 Volvo T5R / '04 Volvo S40 2.4i
Jake_NZ is offline   Reply With Quote
Old 08-11-2018, 07:10 AM   #7
wyatt8740
wyatt8740's Avatar
If you need me to look at my 244, which has a moonroof functioning properly, to see what it is supposed to look like, let me know.
1991 244 (manual 5spd)
1993 245 (auto 4spd [for now])
And the Dalai Lama smiled and said, 'Well my son, life is like a beanstalk, isn't it?'
wyatt8740 is offline   Reply With Quote
