Old 08-05-2018, 02:23 PM   #1
papsimagoo
Delicious Boost! Nom nom
papsimagoo's Avatar
Default How do I swap 90 degree fitting on PS Pumps
20180803_160435
Got a reman AC Delco, similar style, trying to swap because it doesn't include this 90 degree fitting^.
Here it is . Also any advice on removing the pulley would be appreciated.
20180805_110900
89' RSI 245
Delicious BOOST! Nom Nom Nom
papsimagoo is offline   Reply With Quote
Old 08-05-2018, 02:46 PM   #2
John V, outside agitator
some a glued in..On some ZF pumps on some stuff from the ol' BundesRepublik.
Maybe its available as a spare part.. (In kinda the same boat as you cause I have some Mare-Koooor Scorpio ZF pumps which are same as Frod Crossworh ZF pump except no 90 hose fitting and I want spares!!)
Fortunately these ZF pumps I have have a simple 3 bolt flange for the pulley..Youse gonna need a puller and I can recall is Ovlov is Frod or GM puller you need.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 08-05-2018, 05:40 PM   #3
papsimagoo
papsimagoo's Avatar
It's able to spin with some force, but seems like maybe a snap ring?
Old 08-07-2018, 10:57 AM   #4
papsimagoo
papsimagoo's Avatar
Old 08-07-2018, 11:43 AM   #5
planetman
planetman's Avatar
You got the wrong pump.
That appears to be a pump that is supposed to have a reservoir bolted directly onto the pump.
Eric
Torrance, CA 90502
Old 08-07-2018, 12:02 PM   #6
80/20 speed parts club
I have an extra reservoir you can install on that pump. Come get it.
Old 08-07-2018, 12:06 PM   #7
I'm guessing the big manifold interferes?
Old 08-08-2018, 02:26 AM   #8
MasterBlaster
Ah, yes.
Did it come with 2 metal clips, as shown here?
https://www.rockauto.com/en/moreinfo...288021&jsn=541
If so, the reservoir goes into the hole and is clamped to the pump like this:
https://www.rockauto.com/en/moreinfo...287053&jsn=445
What you wanted was this more "fitting" AC Delco version (or some other brand):
https://www.rockauto.com/en/moreinfo...287031&jsn=493
470,000 km so far...
Old 08-08-2018, 03:48 PM   #9
papsimagoo
papsimagoo's Avatar
Damn...yeah it did come with the clips. I posted in wanted and bought this off recommendation... I'll pm you harlard
