Old 08-05-2018, 09:37 PM   #1
supreme940
supreme940's Avatar
Default AC belt snapped
I recently had my ac belt snap on me because of age. I replaced it all the belts with genuine volvo belts, and less than 100 miles later and the ac belt snapped again.
What could cause this? The pulleys do not look out of alignment, and I had a shop vacuum / charge my ac to the recommended amount of refridgerant about a month before my old belt snapped. The adjustment stud on the pump broke when I was replacing it so I used a breaker bar to get the belt tight.
supreme940 is offline   Reply With Quote
Old 08-05-2018, 09:49 PM   #2
apachechef
Burnt Sierra Madre
the brackrtthat holds the M6 10mm head adjuster can be flped over, and it misaligns the belt.
Dammit, Lummert.
Old 08-06-2018, 06:45 AM   #3
DET17
Reformed SAABaholic
As above, confirm pulley alignment with a straight edge off the harmonic balancer pulley. MUST be as parallel as possible.
Do you have a belly pan installed under the engine?
Old 08-06-2018, 08:50 AM   #4
supreme940
supreme940's Avatar
Yes I have the belly pan installed. I'll check the alignment again with the harmonic balancer
Old 08-06-2018, 12:54 PM   #5
DET17
Reformed SAABaholic
Also, the twin Vbelt pulley on your AC compressor might be in failure mode...... when you have belts removed, spin it slowly and feel if you detect any roughness.
Last question: what brand belt snapped? My best experience with these redblocks has come with NAPA or VOLVO belts. Never, ever use CONTI-TECH (I worked for those bastards for 18 years!)
Old 08-06-2018, 03:01 PM   #6
Rusty_ratchet
Rusty_ratchet's Avatar
I've also had good luck with NAPA Pro belts (made by Gates). Gates belts are available from Rock Auto and are less expensive than the ones sold at NAPA. They certainly last longer than CONTI-TECH.
Rusty_ratchet is offline   Reply With Quote
Old 08-06-2018, 03:12 PM   #7
supreme940
supreme940's Avatar
I try to get gates belts or dayco. I used a genuine volvo belt and it snapped. I went and got a driveworks belt for now while another genuine belt comes in the mail.
Alignment was good with the compressor pulley and harmonic so not sure what happened.
Old 08-06-2018, 03:20 PM   #8
240wagonguy
maybe you got an old stock belt? My Dad ordered v-belts for his 85 Prelude, and they came in some packaging that looked like it was from the 80's. He put them on, and predictably the water pump belt failed after like 300 miles.
Old 08-06-2018, 05:27 PM   #9
apachechef
Burnt Sierra Madre
Forgot to mention, replace all the accessory bushings, duh.
Old 08-06-2018, 06:32 PM   #10
I just replaced an AC hose recently and the next day the compressor locked up and chucked the belt. Have you checked for a seized compressor yet?
