Old 08-09-2018, 08:54 PM   #1
Jack
junkman
Jack's Avatar
Default Amazon/544 instrument cluster parts etc?
I’m in the planning stages of restoring one of the clusters.
Where do you get the sea anemone? Inserts that bring illumination to the warning lights?
Other than trying to piece together good warning light logos, does anyone make decals for these ?
oil, turn, amp, high beam
lastly any 52mm tach pods that would look similar to original ones?
I have a small 240 tach that Im thinking about using
Old 08-09-2018, 09:06 PM   #2
300+hp on the shelf club
Maybe check with Joe Lazenby at Susquehanna spares? VP autoparts and cvi-automotive.se may be a place to check. although cvi is on vacation right now.
That rally cluster is really what these cars should have have gotten standard. Looks great and what a find!
Old 08-09-2018, 09:25 PM   #3
Jack
junkman
Jack's Avatar
didnt find anything on VP
not mine... I like the original one. I had the gauges from a rally but theres no room in the dash
Old 08-09-2018, 11:26 PM   #4
JohnMc
JohnMc's Avatar
The 544 uses the same cluster, but the dash exposes that bottom part that the 122 covers up.
That rally dash is pretty sweeeeet looking.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 08-10-2018, 11:15 AM   #5
OttoB
Dear lord. I did a bit similar gauge set-up on my 121, it was 35 years ago. And I still have similar thoughts about hotrodding ab Amazon. I need help.
But you have to cut dash and trim to use that on 122.
Old 08-10-2018, 11:22 AM   #6
JohnMc
JohnMc's Avatar
I once hacked up a nice 142E GT cluster I found in a junkyard and got that to fit in my old 122. Along with the 142E's engine, trans, rear axle, seats, gas tank. Possibly other parts, I forget.
Old 08-10-2018, 12:23 PM   #7
Jack
junkman
Jack's Avatar
I need solutions not history lessons lol
Old 08-10-2018, 01:45 PM   #8
JohnMc
JohnMc's Avatar
It's just a little rubber tube that stops the light from bleeding out all over the place. Maybe try a piece of rubber tubing?
Old 08-10-2018, 01:47 PM   #9
Jack
junkman
Jack's Avatar
that's what I been thinking but I dont want to mess with gluing it in. The stock ones have a lip where it mounts between frame and lens
Old 08-10-2018, 06:31 PM   #10
elmford1
elmford1's Avatar
Valve seal of some sort maybe?
elmford1 is online now   Reply With Quote
Old 08-11-2018, 02:18 AM   #11
OttoB
Strain relief rubber from Mil connector?
Old 08-11-2018, 09:42 AM   #12
Jack
junkman
Jack's Avatar
hmm maybe some small engine might work. Good idea
this might be the easiest route.
Im going to call VDO and see what they say first
for the logos I was even thinking of custom water decals then some sort of clear
silk screen might be too difficult ? I never tried it but after watching 1/20 of a youtube video I feel like an expert
Old 08-12-2018, 05:43 PM   #13
elmford1
elmford1's Avatar
Plumbing/faucet repair parts. There is a bin at lowes/home depot
Old 08-13-2018, 09:19 PM   #14
northNH
northNH's Avatar
Looking to copy something special?
A homemade Amazon unicorn using 140GT parts:
'62 Amazon Blk/red 4Dr '67 Amazon Light green/grn wagon
'69 164 4spd/OD unmolested
'94 MBz E320 Silver/gray wagon '92 MBz 300CE Blk/red Coupe
'86 BMW 635Csi Blk/blk Coupe
northNH is offline   Reply With Quote
Old 08-14-2018, 11:47 AM   #15
matt b
Jack, if you get in a bind: I still have 4 Amazon clusters on a shelf. I'm happy to send you one as parts, just cover shipping.
Old 08-14-2018, 11:35 PM   #16
Jack
junkman
Jack's Avatar
Thanks Let me see if I can figure out the tubes. havent had the time for it
Old 08-19-2018, 05:07 PM   #17
nel621
PTFE tubing
