Old 11-28-2006, 06:55 PM   #1
ShadowofBob
Revived...
ShadowofBob's Avatar
Default Water pump pulley differences
I was comparing my 1991 water pump pulley with a recently acquired 1992-1995 B230F/B230FT pulley and noticed one was much smaller than the other. This would mean that the water pump would run a bit faster than on earlier models. Is there an advantage to this or is there any other reason they switched pulleys? It was done at the same time they introduced the E-Fan setups.
The diameter difference between the two is pretty close to .75"
1985-1991 Left
1992-1995 Right
1990 Audi Coupe quattro x3 - the eternal project car.
2000 Audi A4 Avant quattro 1.8T 5spd
ShadowofBob is offline   Reply With Quote
Old 11-28-2006, 07:08 PM   #2
740Weapon
Traitor
740Weapon's Avatar
slower turning is better.
robs less horsepower.
AND the pump is less likely to explode at very high aftermarket EMS only rpms.
'90 744 16 Valve. 16.317@85.55. Sold.
'92 244. Sold. http://pbase.com/740weapon
Old 11-28-2006, 07:34 PM   #3
ShadowofBob
Revived...
Hmm
I looked at VADIS and it shows 2 types of pulleys for all cars. The turbos got the smaller one for some reason. This is regardless of year. Perhaps it was always like this and I never noticed since my car was originally NA. They also could have put it in there so any future upgrades received the smaller one.
Someone with a -1991 turbo should look and see what they have.
Old 11-28-2006, 07:36 PM   #4
impulse922
i pulled a larger one at the yards the other day just for ****s and grins.
I always thought the car w/ clutch fans got the smaller ones and e-fan cars got bigger ones.
Thanks for posting this though,
-Matt
'90 780 and '03 s60 T5M
impulse922 is offline   Reply With Quote
Old 11-28-2006, 07:56 PM   #5
boosted12a
weapon of mass detonation
boosted12a's Avatar
cool! guess ill be swapping out my pulley tonight. only thing i can think is cause the turbo engines run a hair hotter they want the pump running faster....
91 940 SE, 119K, GOLD
05 S80 2.5T, RED
09 XC70 3.2L wifes gas sucking DD, BLUE
04 GTI VR6 (6 gears of fun) Silver
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
07 Suzuki SV1000S, BLACK, but turing white slowly
Old 11-28-2006, 08:04 PM   #6
rallyvovo
you didnt steal mine did you robert??
:::: 9 series pimpin' ::::
rallyvovo is offline   Reply With Quote
Old 11-28-2006, 08:16 PM   #7
impulse922
in theory that sounds right, but the thermostat is a restriction either way you shake it
and my 90' has a small pulley
Old 08-10-2018, 02:12 PM   #8
oldschoolvolvo
oldschoolvolvo's Avatar
12 year thread bump...
Does anyone have the part number for the later "larger diameter" water pump pulley?
Also, does anyone know the measured diameter of the later pulley?
-Mike
1998 V70 T5
|Feedback|
Old 08-10-2018, 02:16 PM   #9
Jack
Banned
Jack's Avatar
oh wow this is news to me
Old 08-10-2018, 04:51 PM   #10
sbabbs
sbabbs's Avatar
Wow! Go fix yur yota Jack..
