I.M. Weasel
- Sep 21, 2011
- Driving the No Malarkey Bus
So I still have the k-jet main pump under the car, I bought some 100psi fuel line, can I just replace the piece of hose from the tank to the k-jet pump and run both or should I bypass the k-jet pump completely and run the rubber fuel line to the hard pipe after the k-jet pump? Looks like 12mm-1.5 connection, can I cut this off and use a 5/16" compression coupling x 5/16" hose barb fitting?
