Old 03-17-2015, 12:10 AM   #1
theknave
theknave's Avatar
Default Cordless Impacts.
Maybe this belongs in off-topic, idk.
After my recent bj job I came to find that sometimes you just can't pretend that you can get through life without a solid impact.
But what do you do when a compressor is out of the question? Enter cordless and corded impact wrenches.
Did a quick Amazon search and found this which, to me, looks like a good value.
http://www.amazon.com/Bosch-IWH181-0...+impact+wrench
However, I've only really beat on air guns. I don't have any real experience with the cordless ones.
Now, I'm asking for your opinion/experience with cordless impact wrenches. Ones that worked for you, ones that didn't and why... stuff like that. Ok go.
'86 240 DL, M46 - Primer grey, yellow, silver and flat black.
'90 240 DL, AW70 - Rotting, with its guts out, on the cadaver table... the AW70 is nice tho, with a recent full fluid flush via tt 500, and an all new Yukon set of bearings (Timken) and seals at the rearend, new SKF bearings and seals at the axles.
theknave is offline   Reply With Quote
Old 03-17-2015, 12:17 AM   #2
Wren
Porkchop Sandwiches
Wren's Avatar
I have both the 3/8" and 1/2" Dewalt 18V impacts and they are outstanding tools. I use the 3/8" all the time and the 1/2" works great too. I only wish I would have bought them sooner.
Old 03-17-2015, 12:19 AM   #3
theknave
theknave's Avatar
Ah, this is exciting news.
Old 03-17-2015, 01:23 AM   #4
I prefer the Milwaukie impact because it uses a normal trigger switch (not a rocker), and it has better modulation over others.
Old 03-17-2015, 01:27 AM   #5
vlvman
vlvman's Avatar
I want this one because 700ftlbs tightening and 1100ftlbs loosening. http://www.milwaukeetool.com/power-t...rdless/2763-22
Robert
http://www.volvowiringdiagrams.com/
82 244DL, 2004 S60R AWD, 2008 S40 GF's
Had: 77 242 DL, 80 242 DL, 82 245 DL, 89 740 GL, 94 850T, 95 850 GL, and a 02 S60 2.4T
vlvman is offline   Reply With Quote
Old 03-17-2015, 01:29 AM   #6
mikich
mikich's Avatar
I have a corded Milwaukie. Been happy with it, no battery charge/disposal worries
mikich is offline   Reply With Quote
Old 03-17-2015, 01:45 AM   #7
survolvo
survolvo's Avatar
Hilti or bust.
survolvo is offline   Reply With Quote
Old 03-17-2015, 06:20 AM   #8
TestPoint
TestPoint's Avatar
The problem I have found using a cordless driver is that the designers never considered greasy hands. Every time it is used it adds a couple minutes to clean up all the pretty colored surfaces. Mine is only a quarter inch little guy but it has broken free every automotive nut/bolt I have applied it to.
While I have all the air tools for big jobs my 50 year old Black & Decker Commercial corded impact wrench is stronger than any of them.
Ford V8 Conversion Manual -
Old 03-17-2015, 06:44 AM   #9
photoman327
photoman327's Avatar
You hid it dead center. Got the smaller 1/2" milwaukee that is only has 183 ft lbs but eveytime I use it I have to clean it up and put it back in its case. Purchased Cordless for the junkyard pulls.
Old 03-17-2015, 07:59 AM   #10
apachechef
Burnt Sierra Madre
I have that Bosch. I loooove it. Use it for nearly everything.
Next up will be deWalt brushless so I can get saws for same batteries
Dammit, Lummert.
apachechef is online now   Reply With Quote
Old 03-17-2015, 08:53 AM   #11
Stiggy Pop
Stiggy Pop's Avatar
I bought the Dewalt 20v lithium 1/2" drive impact for my Dad for christmas. Turned out he really wanted a hammer drill so asked me to return it. I used it once and decided to keep it for myself. It doesn't have the ultimate power of the air gun cranked up, but it's surprisingly powerful. It's also really convenient to use, very compact, weighs basically nothing. I was and am really impressed with it. The power they get for the size of the motors now is amazing.
'79 242
943 pickup
Old 03-17-2015, 09:42 AM   #12
This is THE one to get IMO.
http://www.northerntool.com/shop/too...9359_200589359
good price on it to.
It's highly portable, compact, light weight, and does 200 ft/lb.... only reason you might need more is for big stuff like crank pulleys.
although if you will only have one impact... it might be better to get the larger 1/2" Drive units so you will never be out of torque. I just like having smaller tools that can fit into more places.
If you are only doing car related stuff the 3/8 drive should be more then sufficient. If you do a lot of industrial stuff with larger bolts then the 1/2 is probably the winner.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 03-17-2015, 09:48 AM   #13
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
[/IMG]
I have the same 1/2" and it's made life so much easier outside the shop, been too lethargic to get an air compressor at my place and at this point I'm just going to wait.
Been looking at getting a 3/8" so I'm not using an adapter at times. zip zip zip
Old 03-17-2015, 11:11 AM   #14
Wren
Porkchop Sandwiches
Wren's Avatar
The biggest plus of the 1/2" unit is that I don't have to constantly trip over an air hose or cord. I've retired my old Black and Decker corded one.
Old 03-17-2015, 11:28 AM   #15
BillLeBob
I use a 1/2" Harbor Freight corded turd that I got on sale for $29. I use it all the time and have had no issues with it at all. I'd like to get a cordless one for junkyard runs though.
1992 745T Full granny spec for now
BillLeBob is offline   Reply With Quote
Old 03-17-2015, 11:39 AM   #16
benski
Post
For me, a MATCO MCL1838IWK 3/8" drive 18v. 325 lbs. breakaway torque, 25 - 250 lbs. working torque. Next on my purchase list is the 1/4" drive smaller cousin. "They're so cute when they're young".
My corded B&D 1/2" has got so many hours on it that the head needs rebuilding. I've owned it since 1987, so it doesn't owe me much. BTW, the Snap-On version of the same tool for that year was a rebadged B&D, for you trivia buffs...
benski is offline   Reply With Quote
Old 03-17-2015, 01:52 PM   #17
nel621
A bit long, skip ahead.
https://www.youtube.com/watch?v=aHoLE7MkpIQ
Old 03-18-2015, 12:07 AM   #18
Wren
Porkchop Sandwiches
Wren's Avatar
Sounds like the one I have. Made back when B&D made good stuff.
Old 03-18-2015, 06:24 AM   #19
volvoboy90
sanna kärlek är svensk
volvoboy90's Avatar
I have a kobalt cordless impact I've used to upgrade from my harbour freight impact that was shooting off sparks. I really couldn't be happier with it. 300lbs of torque. It makes any job easier,and has a great battery life. I plan on getting a smaller impact so I have something a little more versatile, but my kobalt has been great.
Originally Posted by TrickMick View Post
HEY...we're all in this "Volvo stuff" together here @ Camp TBrix...
keeping the "oldies but goodies rockin' down the road"...
*PICK YER POISON*...either put a raw egg under your gas pedal
and tip-toe around town - *OR* learn to live with the GREAT FUN of
sucking unsuspecting "other brand drivers" into the educational benefits
of NEVER underestimating a "grandpa car" again....hee, hee....
RIP TrickMick You'll be missed
volvoboy90 is offline   Reply With Quote
Old 03-18-2015, 09:29 AM   #20
blackbndt
Same setup I've used for years, XRP 3/8's and XRP batteries. I swear by Dewalt Drills, the 1/2 has worked amazing for when I'm out at Autocross and swapping wheels or just at home and pulling leaf springs or lowering subframes.
blackbndt is offline   Reply With Quote
Old 03-18-2015, 10:23 AM   #21
sspony
sspony's Avatar
I have the 1/4" Dewalt with adapters for 1/4", 3/8" and 1/2" drive sockets. Works great! And its small so you can get in to wheel wells and engine bays with it. Almost always does the job!
The bigger ones are nice and have more torque, but a lot of times you can't get them in position to use them.
I know dewalt is making the 3/8" and 1/2" in a more compact size now (lower pic of the two posted by "Wren"), but I believe its more expensive then the larger style.
Regardless of which one you get, pick the compact style. You won't regret it.
Potential, potential, potential....
65' 122s (daily driver)
82' 242 dl
88' 740 "rally wagon"
sspony is offline   Reply With Quote
Old 03-18-2015, 10:25 AM   #22
oifish
I'm feeling extra zazzzy
oifish's Avatar
I've got the Bosch one the OP showed. Love it, the small size makes it easy to fit into cramped areas. Make sure to store indoors as letting it sit in a cold garage during the winter will shorten the lifespan of the batteries.
1990 Volvo 744T M46 - Under Repair - ( ͡° ͜ʖ ͡°)
1996 Chevy C1500 - Current Daily Driver
__________________________________________
Buy/Sell Feedback
oifish is offline   Reply With Quote
Old 03-18-2015, 11:34 AM   #23
Wren
Porkchop Sandwiches
Wren's Avatar
Yeah, they make the lower one in my photo in 1/4" (that uses the screwgun-type bits for screws, etc.), 3/8" and 1/2".
I've had nothing but good luck with DeWalt 18V cordless stuff. I own sawsalls, circular saw, flashlights, drills, impact drivers and more and they are all good tools.
Old 03-18-2015, 01:39 PM   #24
blackbndt
^x2
Old 03-18-2015, 02:19 PM   #25
Hotdoggin
Hotdoggin's Avatar
Blasphemy or not, and I know an entire industry uses impacts to break stuff free, but I prefer to break stuff free by hand, and zip them off with this:
Out in JY's, sure, hammer away, but just for pulling bolts and stuff off fenders, or lots of fasteners in a row, this is hard to beat. It'll break loose most anything that would require 1/4 or 3/8ths, but won't shear off bolts if it won't come loose. I'm a puss.
I think I'll grab that Bosch. It's cute, and I think it's time to buy impact sockets, anyways...
Though, I've done struts on an S60, and never once picked up a ratchet until I went to torque it all back to spec. It's a good little tool.
1978 245DL - B21 Penta carb powered!
1982 244T - Crushed
1983 245DL - SOLD
1984 244DL - Crushed
1984 245DL - Sitting in someone's yard
1991 740SE - girlfriend's car
2008 S60 2.5T - Money drainer
Hotdoggin is offline   Reply With Quote
