TurboDutch
- Aug 5, 2019
- Nieuw en Sint Joosland
I see difference in trigger angle.. you have 92, mine says 60... thats quite some difference...
the trigger offset is somewhere between 85 and 90, if you changed this, this is likely why the car won't run
also do not use the req fuel calculator, just adjust the number by hand, I'd probably start at 10 or 12 and go from there
also, don't listen to people who aren't using megasquirt, it's only going to confuse the issue further.
