hk 40
Banned
- May 15, 2011
- RTP, North Carolina
^ really nice
I know the Chinese rods would be fine I just don't like sending money there for that sort of gear, I happily pay double to buy something local but after more reading the 13mm rods should be fine for what I want to achieve.
Tanks for the info on Springs, do you know if there is a difference between 16V NA springs and turbo ones?
I have found a 16V complete NA engine for $300 which seems like an OK price in Australia.
I think any one in his right mind would prime a motor and check for oil pressure before ever running it. sure it should of had the pump gear in it but you can never take a motor for 100% preowned.
Which state are you in? I'm fairly certain NSW laws won't allow an engine of that capacity in your car, just go with a 20B
Yeah I have been to the workshop where the final machining is done, forgings are done in Aus but not in house.
I have nothing against China, I just hate people in Australia that send all their money overseas and complain we don't make anything anymore, we are a bunch of hypocrites over here.
Yeah I have heard some bad things about DMS over this way too, had heard you need to keep spares but hadn't heard about any structural failures, but that was only word of mouth. I bought AVO shocks for a previous Mini and they were a joke, I have no idea what the springs were supposed to be rated for but I'm guessing it was a go cart not a mini, only two of the shocks were Gal plated so two rusted in no time at all, every country makes some crap gear.
So, back to the engine haha, I am going for a 16 valve engine if it flows better I should get more power at lower boost levels which is good for everything, yeah it sounds like a bit more work but it sounds like it's worth it.
Has anyone had any luck with shimming valve springs, I have never tried it but it may be enough for a mild boost increase...?
http://www.summitracing.com/parts/mll-bp3834ctc1/overview/make/chevrolet
would you expect to have this run right the first time you turned the key? would you expect it to perform as advertised?
and i think it's still cheaper
you missed my point, you were criticizing someone for buying a crate engine and not assembling/testing it themselves. my point is, at some point, it should not be necessary. you can pay someone else to do it at a higher cost
Scrap your s60? why dont you use its motor?
M56L
1st 3.38:1
2nd 1.90:1
3rd 1.19:1
4th 0.87:1
5th 0.70:1
final drive 3.77:1
M56LK
1st 3.38:1
2nd 1.90:1
3rd 1.19:1
4th 0.87:1
5th 0.65:1
final drive 3.57:1
M56H
1st 3.07:1
2nd 1.77:1
3rd 1.19:1
4th 0.87:1
5th 0.70:1
final drive 4.00:1
Your statement is just a tad terse there mate, don't know if I can really agree wif it.
Or not.
Might want to clarify your thesis and explain what you mean...just a tad more verbosely.
RWDNoob said:Also I really like the ratios in my S60's M56, they had a nice spread, not the best for racing but for a day to day car they were fine. I was trying to find Volvo ratios but the link on the articles page is dead, I'll have to have a look if my trans still has the diff ratio sticker on it.
